  • Replies 294
Sure you can get your wheel back.
When to do it? Ring me on 0421009474.
People who turn up on the day without paying a deposit to me can turn up on the day, but they will have to wait at the bottom of the list.
Edited by gtrGhosTDoGG11
Sounds like a very well matched package.
I've since seen your thread on AUS LS1. Very nice result.
That initial 150rwkw is pretty awesome. What RPM was the dyno run started at? :D
13.2 1/4 was run after the mods?
Edited by Cubes
cheers, ill pay you dyno deposit as well i spose. Oh yeah and have your stock parts to return.
Edited by popeye132
don't think i'll put the corolla on, might break something with all that power, hehe!
Looking forward to it, do we have times yet as i have an engagement party in the arvo and work in the morning but i will definitely be there for sure to check it out!
That initial 150rwkw is pretty awesome. What RPM was the dyno run started at? :P
Yes, run just a couple of weeks ago.
There's more there on the right day.
I was consistently 2 tenths quicker than a guy who has run 13.09 on a T&T prepped track so there's a 12 in her. Hopefully a mid 12 if I can scrape together the funds for a high stall.
Had my white GTR dynoed by Shaun yesterday. He got it up the drive no problem. It ran 249.8 rwkW, 18 kW more than my grey GTR! Now I have to decide which car I should take (unless the white one sells before then).
I'm in.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
Ă—
Ă—
