What's recommended?
My current car has a Mongoose M80S in it (triple point immobiliser) which I like. My mate's Liberty B4 has 7 point immobiliser. Does anyone know of systems with more than 3 point? Or simply a really good system? Otherwise I guess I'd go the M80 again, but I'm after other opinions...
https://www.sau.com.au/forums/topic/90504-whats-the-best-security-for-r33/
  • Replies 51
its not the alarm that is important, it is the install. basically if u go to a normal place ie jbhifi and get an alarm and they do the install cheap(as usual) then u wont have good security no matter what alarm u have.
With the install u get what you pay for, so if you want a good install(and therefore security) be prepared to pay lots more than normal.
What's recommended?
do the M80G this time. adds glassbreak to it.
get it installed PROPERLY!! if you can see it under the dash then I can remove it in 30sec and drive off.
tracking would work IF you had coverage. GSM would do it but beware of smart thieves. ( pm me if you want an explanation of this.)
as for the liberty alarm,
I had to disable one of these and did so in a very short timewith BOTH modules being removed from the car. clipping the internal siren took a second to do.. external I put a wet rag over.. car was started and moveable for a local shop to work on it 5 minutes later.
sorry to kind of hijack the thread...
does anyone living in adelaide know much about Tisonics alarm systems?
They're locally manufactured and have features such as integrated Turbo Timer, Glass breakage, tilt, and microwave sensors - all at a price of course.
I had one installed on my silvia turbo when i bought it and their install looks professional enough. Now looking at an R33 skyline and considering the same alarm system...
What I want to know is if anyone can give more info on just how good they are as far as alarm systems go...
no alarm is 100% fool proof
unfortunatly the best method is to watch you car and what you do with it... lots of little things help
like not blaring your music and then stoping the car and getting out... a good suggestion would be to turn your music down 2 minutes before you get to your arrival place .... and also where you park.. eg near people, nearlights and for what periods of time you leave it
other then the security of yourself being close to your car... a good well known alarm and immberliser should do
if your ultra paranid tracking is a good way to go... but like i said the best security is common sense
-Ruffels
^^^ yeah but like any alarm system theres a way around itthe keypad is just a very hi tech switch... the keypad is in series with the igntion wires and unless the correct pin is entered the ignition wires done get connected, resulting in the car not being able to start.. theres not alot stopping a thief getting in beind and re wiring it to suit them quite quickly... no alarm is 100%... the key to a good alarm is deterence
allthough with a million and one different lock out mechanisms.. you'll find 99% of the time your only making life harder for yourself when you loose/lock your keys in the car
-ruffels
Another way to have your ignition wires running through an electronic switch is with a remote start alarm, (i.e. viper 791xv). This is also a 2 way paging system which means that properly installed your remote notifies you if your alarm is going off and why. Cost RRP about $1000 for the full system, but then add up to $2500 for fitting especially if you want accessories hook up.
i'm thrilled with my mongoose. very impressive alarm. the quality of the installation is the key.
brant alarms have a good rep, being 6-point really only means 2x 3-point setups. similar story in the rexies/sti's/etc etc.
i believe remote-start alarms are, technically, illegal in most states. i've read this a few times. can anyone confirm?
krzysiu is on the money tho. who is going to break into a car with a dirty great mutt in the back seat!!?!?!?? hehe :P
d
if brant was still in business then it would be a good thing. I remove mopre of them than I fitted originally. especially from WRXs.
Mongoose alarms are the go when well fitted. toss them under the dash and I'll have it out and be driving away in a minute or less.
Rotties on the back seat - yep! though I dont think my Bull mastiff would agree.
just purely out of curiosity where do you usually put them, esp in cars with very small dashes?
d
Do you think the mongoose alarm is better then then viper 791xv?
Mark.
If you are in NSW (sorry if you have stated where you are from) you can still get the Brant Nemesis installed, aparently there is a new one that has a tilt sensor and auto window winder (mine doesn't..)
Search the forums, Alan Jong I think it is installs them.. He's great, if your near Chris, i'd suggest you take the car to him though..
Brant is quite expensive - your looking at $1000+..
Although I enjoy having a keypad.. makes me feel that little bit safer..
Mark.
personally, i think the mongoose is the best alarm on the market. :( i did HEAPS of reading into what was out there, the consensus being viper mongoose or auto watch. the m80 had the features and had the price and my installer knew what he was doing so yeah. i'm happy :D
d
d
depends. mostly in a bitch of a spot that you canoot get from under the dash. no going to say where as that poses a bit of risk. some cars get the dash pulled if its a small car ( EG starlet )
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
