not so bad, you can now buy something that works. HUMM, maybe i should do thesame. LOL.
On another note, i scorred all the gaskets and studs and bits and pices needed for the exhaust manifold repair for $154 all up. YEEHHHAAAA.
Looks like i have sold my snotter :(
damn :ermm::ban:
you can both buy my 33 :O , hasnt missed a beat :w00t:
:O you shouldn't even have to ask what the plan is!!!
damn :ban::(
you can both buy my 33 :ermm: , hasnt missed a beat :w00t:
Still got the turbo for sale though Toff :P
Id love to buy your 33 but i just need some wheels to get around the net few weeks as it is without being fancy!!!
wogs....what was your torque reading on the 25?
at 170rwkw my torque was 550.2Nm !!!
dam thats ship loads. maybe i should bold an old rb30 in my 32 and bolt on a dirty old turbo. surly that would spin the wheels easy.
hahahah, you can feel the torque, well after owning silvias, r32 gtst, r31 gts with rb25, 300TT, vr4 etc etc.....Like the torque of the RB30.
Yeah turbo on, just sorting out the little problems like getting the raditator flushed today and the flywheel machined (damn vibrations in the clutch made it look like I was a retard trying to drive)
LOL. yeah i miss tourqe, the magan has a bit over 400 nM at the front wheels, and that is GREAT, any gear, bag, your away. Skyline, you need to rev it to get anywhere. LOL.
Well done mate, can't wait to see it.
On an up note, found out last night that my FICD, FIRTS IDLE CONTROLL DEVICE solenoid, doesn't work. See if this makes any differance.
plan B, build the bitch up, pronto. LOL.
That requires money and i owe more than i have let alone coming up with enough to rebuild it.
Im going to strip as much off/out of the shit heap as i can and flog it all along with the rolling shell!!!
Then once thats done im out of cars for a while, IM OVER THEM and all there PROBLEMS
Before you get too excited about torque figures remember a dyno set up in power mode (eg rwkw) will not accurately measure torque.
I mean, if the dyno was set up for a torque reading and you got 550Nm then that's an awesome result, but if it wasn't then there is absolutely no truth in that figure. This was a big problem after the dyno day with Dr Drift when everyone started saying "I have such and such Nm", when all their figures were complete rubbish.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
