spose ill update lol,
new hks2530 was put in a month or so back same with bosche 040 pump.
have powerfc, injectors and z32 waiting to go in as well as an oil cooler/reloc kit.
new body kit is being worked on and nearly done.
suspension should be here soon..hopefully!
nothing happening to the rx7, but plenty on the mitsubishi side of things... the lancer will soon be ready for new paint.
the skyline goes into the bodyworks for tidy up soon too.
So...
- Now have a TT 5sp Soarer
- Have pulled the turbos off
- Am just about to fit TR43i, stainless manifold, 50mm gate, Walbro pump, FMIC and make custom exhaust and cooler piping
- Just shopping for an adj fuel pressure reg and ecu/piggy back
Also, just picked up our new family bus.
well pick up my car today with the new turbo fitted :) trail fitted the body kit side skirts and rear bar very very average fit :down: will be fitting bonnet tonight, so ill wait and see how good that fits
got the rx7 back with the engine removed! (was going to do it myself but no time at the moment and need to get things cracking if its gonna make the start line next season!)
will now strip the engine of all the crap on it and the gearbox then its off for freshening!
the engine bay is pretty tidy, but will clean it up and repaint.
There will be nothing left if you do that Stu :)
I need a knock sensor to finish my car off :down:
well few pics from todays vist :D
Body kit fitment not to bad side skirts need a fair bit of work but front and rear just a lil trim here and there and will be a perfect fit,
few pics to give you a rough idea of what it will look like when finished :down:
Guess i better do an update on mine, it's sat in a corner of the shed since i picked it up from having the cage done, so this weekend i pulled my finer out and gave the inside a cleandown and started painting it. at this stage it won't be back on the road til jan, but hopefully before christmas. On another note, anyone interested in buying it?
^^^ love the bonnet and a nice choice of kit, 34's can look horribly wrong but that kit makes it look wider and neater.
GT-R made 270kw on 15psi and made 1547.3 n.m of torque.
will wind up the boost (around 22-23psi) next tune to see what i can get out of it.
^^^ love the bonnet and a nice choice of kit, 34's can look horribly wrong but that kit makes it look wider and neater..
thanks mate :thumbsup: well car is now fixed no more break down at 4600RPM coil packs FTL :huh: but all good now :ph34r:
Mines coming back together now. fitted new radiator and put all the loom back and other bits and peices that were removed for the respray. should be on target for a pre christmas finish. anybody got a interior carpet for sale?
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
