he's refering to Pete Nunn, not brad. Brad's car does indeed have massive power and ballistic brakes
he competes in the TSS, so no, not just setup just for symmons, obviously baskerville as well. And yes obviously things are changed between the two circuits. last race meet at basky he broke the lap record for that class, GTA.
the original 32 gtst loom is around 25kg including all the small ecu and control units. bens targa car had to have a fair bit of stuff added over the top of what was stripped out plus it still runs electric windows and mirrors ect.
once you have stripped a car of the easy cheap to remove weights it is hard to find 16odd kg on one area that doesnt cost a bomb so we are pretty pleased with the result.
im yet to do a r33 so im not sure what the starting weight would be.
aparently the r35 has a tun of wiring weight but because of its complexity no one has tampered with it much.
All the throw away wiring from handbrakes WTAC R35 GTR
Oh ok, forget me then :thumbsup: sounds very impressive!
and i was going to find that bodie, anyone that hasnt read the whole build thread on Handbrakes R35 should do so
Edited by jangles
update on her gtr, have just about finished the hicas removal just need to sort out the plumbing around the rack to pump, lockbar is fitted just need wheel alignment then were done.... Plenum is completely off ready for the new one all all the piping and catch can finally sorted, should be back on the road and driving next weekend... Arrr cars.....
stevo
Edited by GTR_001
Ah i get this all the time. this joke is seriously old.
less weight is free power and free brakes. its simple phisics?
how do you think an rb20 powered r32 can lap basky in the times it does? no rb20 r32 has ever done it before? it doesnt have massive hp or belistic brakes?
its not the .25kg from one thing either its .25kg from everywhere.
its not possible to run Nos everywhere Justin. if it was it would probably have it.
Oh Damo... I know I know..
If you strip the whole car loom down to the essentials, it's going to be a little more than 250g. And it is all the little things that add up to one big weight saving.
But as a regular person 'mod' so to speak, it's alot of cash outlay for a small gain if you can't do it yourself.. imagine what you would charge a punter to strip out a engine loom, strip it down and re install it.
But gas is still AWSOME :nyaanyaa:
No suspension changes have been made to the car for the last few race meets.
Only difference was the new engine this time at symmons.
Are you talking about brad or pete?
If you like Pete Nunn Motor Sport on facebook you can see how much of his loom he took out, fkn heeeeeeeeeeaps.
Things are starting to look good have finally found a pump pulley, new intake and cam cover gaskets have just arrived and ordered my new silicone joiners off barsny all i need now is for the new plenum and covers to turn up and get a few new lengths of -10 hose and were back on the road...
mmm polished goodness.....
:whistling: helloo :thumbsup: very nice
i have been lookn for hose's like that but cant find good quality ones let us know wat you find i seen some on ebay but dont know if there a rip off
ive got a local contact that supplies braided speedflow and pro flow standard braided and teflon braided hose if your iterested, im picking some up on friday to plumb up our catch can.
can you upload a pic once you get them sounds like wat i need
i have the turbosmart blue ones on the bov ect thinking of going braid lines to my catch can as its some dodgy looking blue hose at the momentyucky.gif
heres a link to the turbosmart vacum lines
http://www.hpheaven....&cat1=40&page=1
Edited by Autumn33
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
