Well after a few interesting weeks of having her gtr of the road and in pieces it is finally all back together and going again with a steady idle just under 1k, all that's left to do now is a few highway runs tomorrow to set the boost controller up...
Old Engine bay shot.
New Shot with pretty bits fitted...
got new tyres for the 31 today
$107/each fitted (in QLD) for 235/45/r17 Achilles Sports (supposed to be very good for the price)
anyone know of anybody in tas who can get deals like that?
(this was from Japanese parts and performance on the gold coast)
Just in the process of sliping the motor back into the R.
then make up a few oil cooler line's,fuel line's, fire thold girl up.
then strip the inside of her out, then off the Chris Tanner @ Performance Fabrication
for a full cage,
Then into the spray booth at Robayne/Optimum coating's for a fresh lick of paint.
quick tune at Pro Auto and back on the road hopfully...
easy way to spend $7-10G's in a few month's!!!
my new pcv valve arrived :D
popped that in and it seems that everything is back to normal (was doing a couple of tiny weird things before)
$23 from launceston nissan, $11 from Amayama :)
Been a while since i've been on here , 34 is 'garaged' at another location atm because lil scum tried to break into it again and stuffed the door locks (which did their job thankfully) . Will fix it up soon enough and sell it on , which i'll be doing with all my cars now , gunna get out of the imports for a while i reckon
hey guys dose anyone know someone that could do a bit of sanding/priming for me? (rear quarter needs the line sanded back into it near the tail lights)
would preferably like it done before Saturday
Cheers
A decent amount of stuff happened with my car over the last few weeks.
Had a knocking noise the other day as I pulled into the driveway, which turned into a horrible rattle/scraping noise the next time I started it. Had my mechanic over and he thought it could be the timing idler/tensioner coming loose, but it turns out it was the harmonic balancer wobbling around and it was rubbing against the engine.
It had eaten out the keystone on the crankshaft and created a lip in front of the timing gear, and because it had arsed up the crank a bit we were worried it may have screwed up the timing gear or it's key stone/area on the crank as well. Ended up pulling it all down and replacing the water pump, crankshaft seal, timing belt (with a full new kit) and a new crank timing gear because we ended up drilling the other one off :P a bit early for the timing service, but meh.
In slightly more awesome news, I got my new QFM AR1M brake pads the other day, just need to get the rotors machined and get them in now :D Also, my car has a few goodies stolen off Veeto's poor car now, the 3.5" exhaust system and the rear strut brace. She's running a lot tighter and louder.
finally after 3 months or so of ben and i tinkering ive got my streeter running sweet. best its run since i got it just in time to go to a new home. haha
ive had a battle as the cause of my problems was multiple sensors. one was just masking the next.
ive always had a thing against selling cars just once you get them sorted but i can see how the frustration can cause people to just want to see the back of a car.
i can now garentee it will go smoothly for the next owner.
    • I'm going to slap an old nismo logo sticker on my spare one and sell it to the land of the free for a thousand bucks
    • lol, probably should have read further!
    • Well - they have arrived.  And they are easy on the eye to put it mildly... These only have three bolts - but for a start there is a key that fits with vacuum like precision..  And as you can see by my ruler, the interface is large..   I listened to a podcast on HP Academy about Dan (KiwiCNC) and I'm more than comfortable he knows what he is doing. R35 Bearing assembly should arrive later today so can mock that up for a look. Can't wait to get these on and get some brake pressure logging too. IMG_3860.MP4
    • I would be very confident that they are the same parts (the 2 different SKUs). It seems very clear that you can drop the cam in the 2-way opening, or in the other opening. If you arrange it in the other opening in the same way that you see any other 1-way diff, ie, with the flat of the cam up against the 1° side of the opening, then it would work as a 1-way. It can only spread the ramps when driving forwards - cannot spread the ramps on overrun. It would then appear obvious that if you put the cam into the opening "backwards", that you would get the angled flats of the cam working onto the "points" of the 1° side of the opening, which would give you ramp spread in both loading directions. I do wonder if the forward direction of the 1.5-way config is equivalent to the forward direction of the 2-way, seeing as the cams are flipped and the angled surfaces on those would need to be the same on each side - AND - clearly when installed in either the 2-way or 1-1ay configuration they are not intended to work exactly the same (the ramp angles on the 2-way are 10° different between forward and backward, and the ramp doesn't exist in the 1-way config). 'twere me, I think I would rather actually have a set of rings that offered the 2-way with two different sets of ramp angles, say the 55/45 of the existing design and maybe a 45/37.5 combo for a less aggressive effect), AND another set of rings with a dedicated 1.5-way opening and a dedicated 1-way opening. The 1.5-way opening would actually have the steeper angle on the overdrive side that causes it to be less pushy than the forward drive angle, like you see in many other diffs. But really - if this Nismo thing is thought out properly and all those surfaces work on each other the way that they need to, who am I to argue?
