once you paint that it'll look shmick as!
I provide the best in R33 body parts, as you can see in this example, it's come pre-wall tagged and pre-jap stained! If you buy your jeans already f**ked, why not your body kit! LOL!
few quick pics of my datsun with new wing mocked up into position. fixed the few little marks on my drivers side door today and brodie primed it up for me, he also painted his cooler for his GTR.
going to get my beastie painted up and kit back on in the next few weeks. got the oven booked. will get cage in it in a week or two.
getting there, bit by bit
thanks Jay.
scouted the globe for a wing I liked, well to be honest I dont 100% love any wing on a 33. I think the best overall looking wing is the S2 wing. GTR wing is not much chop even on a GTR, S1 is shite, stealth wing is overdone, okay on GTR drag cars. Anyways the point of is it is handling, aero grip. I want to dabble in super sprints and time attack and hill climbs and aero is something I want to play with.
car will be back together soon, will look okay with splitter etc all painted up. will get pics up when I'm done.
the beauty with wings is, they bolt on/off. this is the 4th wing thats been on my car over the last 4 years =)
if I wasnt setting the car up for light motorsports events I'd still have a stealth wing or S2 ;-)
cheers
finally put my new radiator in, fresh green coolant too :)
seems to be working at last but i'm not sure if i should change my thermostat, its a 78.5*c or something on and the stock one was 87 i think (r33'r run an 82)
i was going to put the 33 one back in but i couldn't find it and its not a genuine one (the opening looked smaller between the two)
little update vipec goes in this week also going to piss the cannon off and go twin 3inch stanless insted :D also .. i took my stupid flopping hks digital boost controller out and hooked the std one back up as the vipec uses that cleaned up the engine bay shit loads
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
    • So 10/10 times that code is coil packs? I mean if that's the case ill drop the $400USD or so to replace them. I didn't know these cars threw codes before the issue became an issue.
