I want one, I want one, I want one, I want one, I want one, I want one, I want one, I want one, I want one, I want one, I want one, I want one!!!!
NEED A Splitter and a mad wing :(
I wish I had mad fab skillz...
hahah the cars name is sooty. now its sooty the transformer, 'dattotron'
just a slapped togther pic, still got things to do on the front end, going to put a new water pump and belt idler/tensioner etc on it and a few other odds and ends. still got brake ducting, crabon plates and mesh to go back in her. Roll cage (woolls old Bond cage) and few other rear suspension bits sitting the in workshop waiting to go on. just wanted to get a pic of the ol beast as i'm away next week so wont get a chance to fit it up properly for a little while. still got lots to do, but i'm getting there. hoping to run at every hill climb & supersprint next year. :banana:
so i been playing around trying to get my engine bay lookn better thought id add some pics of wen i brought it and wat it looks like now engineold1.jpg
Engine bay looks pretty mint, did you paint the throttle body black??
i really dont know who he got so much dirt mud and wat not in the engine bay
also waiting for the vipec 2 come from NZ so next week should be a good1 :D
cheers Brad. looking forward to giving it a run.
Yeah funzy, thats next. I'd like to fit a Capel motorsports diffuser, but atm I'm just going to flatten it out under the ass from the diff back, get a decent angle and smooth up the airflow a little. thats going to happen in the next couple of weeks. the budget datto is starting to take shape. :cheers:
bozo3.jpg?t=1318474713
how much to make me one to suit the stagea?
probably only needs to be a little longer, i have a flange near the diff too
quick pics
Edited by pipster11
if you get some bits sorted i can nock you up a set when you come try these wheels on.
phew , i thought it looked horrible in the first pic , looks much better in them! , how far under the car does the front diffuser go?
its 700mm deep, so back to the swaybar. 5 inches past the bar at the front, 4 inches at the sides
been tinkering on my car getting it ready fo a tune.
one thing thats been bugging me was how untidy all the wiring looked on top of the throttle boddies, so i made up a carbon cover for it
also put some mesh in my headlight duct.
only a few small jobs and its good to go.
That cover looks the goods man. Did you just make a flat piece of carbon then cut to suit?
Well I've almost got everythimg bolted on my engine ready to drop it in hopefully next weekend. Spent today modifying the external oil drain as it didn't clear the rear dump pipe so had to change the bottom 45degree fittings to 2 90degree ones and now it's sweet. Put the last few things back in the engine bay and got that tidy ready for the engine. Now all thats left is finish the turbo oil/water lines, oil drains, set up the timing, put the clutch on and drop it in. Then comes the fun part of connecting everything......
post-58307-0-63022500-1319360807_thumb.jpg post-58307-0-24956800-1319360760_thumb.jpg
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
