so i have noticed my top radiator hose connecting my engine is leaking a bit with what looks like some corrosion around where the clamp is, will look at it tomorrow, cause the cars hot atm, just wondering how you can tell if the water pump or thermostat is stuffed?
also on a stockish 33 where should the temp gauge be sitting, lately ive noticed it at pretty much half way, but for some reason think that when i first got it ti was lower
so went and took the top radiator hose off to check... and found something i def didnt want to see, the bottom part of the bit the rad hose fits to had rusted! :( took a photo will upload when i can, so searched the forum to see if there are any fixes, found a thread where one person said they had to replace the entire lower plenum, if thats what its called.
another person said hes just hammered in a pipe slightly smaller to fix it,
i guess replaceing the whole thing is the best, is the second an ok option?
any other ideas?
for the moment cause there was enough still remaining i moved the clamp so its actually sealing... or seems like its sealing, but def gonna need a fix soon!
bit on the engine
pretty much like that, cant figure out how to upload again :S
http://www.skylinesaustralia.com/forums/topic/391336-radiator-rusted-pipes/
Edited by MatthewT85
The rusted pipe is a press fit into the bottom half of the inlet plenum, so with a bit of difficulty you can crush it inwards and remove it, then if you know a machinist you could get them to make up a new piece with the right tolerances to press in. I have been told you can buy this piece but I couldn't find one, there's no part number for it in FAST so I doubt you would get it from Nissan. So it would probably end up being easier for you to buy a new inlet manifold.
thanks yeah thats what i was told by a mechanic, he'd seen it a couple of times, he also said that someone like midas could make one up easily, not sure now if i want to try and remove the old piece myself now... :s
yeah nissan dont make that part which sucks, did try and see if aftermarket plenums had the same size but couldnt get it separate to find out so looks like getting one made or new inlet manifold is the way... which is also a lot of messing around
yeah ive now been given that option, radiator place said they would remove the plenum nad then weld a piece on, mechanic said theyd remove the pipe and fit a new one, i think what im going to do is just get it removed and then new one fitted, and if anything goes wrong then yeah will be looking for a plenum... hopefully wont come to that though. but ill keep it in mind!!!
  • 5 weeks later...
so about to do an oil/filter change on my car, was wondering what everyone uses to remove the filter, mine was previously done by a mechanic, so who knows how tight its on....
i went down to supercheap and have seen things like these...
http://autotulsablog.com/wp-content/uploads/store/products/thumbnails/1366600846836841.jpg
http://www.supercheapauto.com.au/online-store/products/Super-Works-Oil-Filter-Wrench-Cam-70mm-76mm.aspx?pid=13035#Description
http://www.apextrading.co.uk/media/catalog/product/s/t/strap_filter_wrench_1_1.jpg
im kinda leaning towards the first option, cause it looks like it would work best...
So I finally got around to getting another 32..
Mods:
Carbon bonnet
GTR wing
GTR grill
GTR front bar
Front & rear strut braces
Bosch 040
Tein coilovers
Rota grid wheels
3" exhaust
Fmic
Basically sums it up..Hunting down some M-spec skirts then doing a respray in the silver
http://autotulsablog...00846836841.jpg
http://www.superchea...035#Description
http://www.apextradi..._wrench_1_1.jpg
Use K&N filters... they have a 3/4 nut on the end of the filter. Makes it super easy to get off. And they're an awsome filter.
I wouldn't bother with a strap on an rb.
Justin.
Few new pics of mine, not much new made up a metal intake & removed blow off valve,removed a/c control/vents as it was stuck on 22 degrees all the time & removed the rear section of the exhaust(did that a few months ago)
Pics:
So I've organised for the minor body work to be done next week, Just trying to organize someone to repair x2 tiny cracks in the front lip on the front bar & a crack in one of the side skirts, Then I'll be removing odds & ends & taking it down to the booth for a complete outside respray in the same color + painting the carbon bonnet aswell
**Sat side skirts on to see if they would suit, I'm convinced"
been awhile sence ive been on here. now got another 31 with allready a few good parts in it
nistune, gtr injectors, kkr430, cooler, 3 inch, cusco s13 coilovers, s13 knuckles and hubs, bride seat, 15x8 super lights.
allready gone xf throttlebody, s13 lca, moded knuckles, n14 rackends, s13 tie rods, hydro hand brake and 17x9.5 +18 drift teks, flip cooler and shorter pipping
ok so previously i had been getting a mechanic to change oil, i think they were using penrite hpr 15 oil, which i think is 15w - 60, was talking to my bros tuner and he recommends castrol edge 10w - 60 so when i decided to do the oil change myself switched to that.
i have noticed with old oil, when cold start it would be at 6, warm 2, cruising 4.
switched to new oil and cold start is just about 4, warm 2, cruising somewhere around 4 is this down to difference in oil?
or has gauge randomly stuffed itself, or could something be wrong????
also all on stock gauge...
also changed fuel filter at the same time, but doubt that matters
0 f**ks currently being given about the stagea atm
chenged the caster bushes and front upper inner control arm bushes to superpro adjustbale ones and changed the rack bushes too
still haven't had it aligned so i've been driving the 31 to work
found while it was on the hoist that both inner cv boots are toast and the grease has gone all milky looking (must have been like that for a while)
and the passenger side rack end has a slight bend in it too, awesome
oh, and i had pedders inspect it a few weeks ago and didn't notice any of this even after i told them that i nudged a kerb pretty hard on that side
also, my awd isn't working cos one of the rear tyres is more worn than the front tyres and it keeps feeding power to the front on the highway
turbo is on its way out
needs a tune
and generally feels like a massive ball sack to drive atm :(
/rant
Edited by pipster11
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
