so currently my car has a turbo back exhaust and pod filter and boost hits about 11psi and drops to 10, im about to install a jjr return flow intercooler will it make the boost go up again? I know the stock ecu has a shit fit if theres too much boost, should i get a boost t to prevent that from happening? or should it be ok...
A 'boost teee' isn't going to get you less boost.
I don't think you'll see anymore than 1 psi or so increase with a different cooler, if any at all.
Justin.
Edited by XRATED
Ah k yeah I get what you mean, should have thought about that, thanks
Didn't think it would go too crazy, just read things about having too much boost on stock ecu, but I guess it's people turning it up themselves
When you planning on hitting the track Toffy?
honestly im not totally sure mate , i want the car tuned by the end of the month with all the goodies on it i've accumulated , it only needs indicators for the front and a rear ball joint (and wheels, which are on another car) to pass rego which will be done next week , then i can go to town on it :D . hopefully early Feb i want to take it out on a practice day/private track day or whatever you call it to do a little test and tune , then im hoping to make the first drift prac . it could all go to poo if something goes wrong with the car though , but that's my aim :)
When will yours be out and tearing up the track?!
Edited by toffy
I hate setting goals as I always seem to underestimate how much time things will take, but the good news is that everything is starting to go back in the car. I'd like to say it will be track ready by the end of the month but there's a couple of potentially time consuming things that are out of our control, so we'll see what happens :)
installed my return flow fmic wasnt too hard just takes a lot of fiddling around, doesnt help being massively hungover...
pretty happy with it just went for a drive and pretty surprised by the temp diff on either pipe.
next to change my thermostat and coolant then onto powercruise :D
hmmm so i changed my thermostat and bled the system ect ect, then went for a drive and then looked under the bonnet to see that coolant was coming from between the thermostat housing and block, so looks like the gasket sealant i used didnt work/i didnt use enough.
http://www.permatex.com/products/product-categories/gasketing/gasket-sealants/permatex--aviation-form-a-gasket--no--3-sealant-liquid-detail
that is what i used, left it overnight and then filled with coolant.
cause i have to do it again, should i use that stuff again?
i also have this:
http://www.supercheapauto.com.au/online-store/products/Permatex-High-Temp-RTV-Silicone-Gasket-Maker-Red-85G.aspx?pid=114981&menuFrom=51001#Cross
which would be better, i found that the first stuff i used, you couldnt use alot cause it would just drip, sort off cause it was too much like a liquid...
http://www.permatex....t-liquid-detail
i also have this:
http://www.superchea...rom=51001#Cross
rb thermostat gaskets are pretty hard to do with sealant
it took me about 5 goes to do the stagea
the easiest way is to spend $3 on an actual gasket from supercheap
ha ha i was annoyed already at having to do it twice! 5 would make me crack the shits!
but i used the ultra grey and it would perfect.
had no problems at powercruise :D
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
