bilsteins out (too firm for what i use the car for, and to be honest the suspension i had before was pretty much perfect, just a little high)
drove it to the drifting
also its running a bit shit at first with the cold mornings, everything runs as normal once the water is over about 60°C
could be the plugs, they are iridiums but i've probably put 60,000 kms on them already :(
I asked about for you but the people i asked hadn't seen you
If you've still got that 3" cat i'll take it Peter
also, the car looks good from a distance, but there are a few problems when you get up close
Edited by pipster11
so when finally get round to changing my rocker cover gasket im gonna change my spark plugs too, ive been reading around and looking on the ngk website they recommend, pfr5g-11, but ive read a lot of people just go with coppers - bkr6eya and im assuming once again -11
would that model in the coppers be the right ones for me? all i have is turbo back, and front mount.
aslo with the rocker cover gasket the half moon, when using gasket glue do you only put it on the curved edge, not flat?
also wanted to go the drifts... damn work
Edited by MatthewT85
http://www.skylinesaustralia.com/forums/topic/104405-spark-plugs/
Yeah sorry I didn't have a chance to catch up with you, I was so busy I didn't even have time to scratch my self! If you're looking for me at a drift event I'm usually at Pit Exit or Race Control ;)
yep thats what i read, just saw they had BKR6EYA and someone else had BCPR6ES
but i think ill just stick to the bkr6eya
BCPR6ES or 7ES's
I've only ever used 6/7's 180-400+ rwkw
ok thanks yeah thats what sorta got me confused between the two, i think i read in there that one 'neck'/bit that sticks into the coilpack is longer....
am i right in putting the gasket glue only on the half moon curved piece? and the rest is fine to leave
thats ok mate
I saw Alan in the commentators booth (rather he saw me)
If you want to bring that 3" cat up to the sprints of whatever is at symmonds this weened i'll gladly take that off your hands, don't think i can do the wheels atm, don't quite have the money for it atm
Don't be fooled into buying anything other than coppers either.
i've always used copper BCP6res NGK plugs in kermit, at approx~25 a set i simply replaced them every 5k when i serviced. they comein 2 types that ive found, if they have 11 on the end they are pre-gapped to 1.1, if they have no numbers, they are generally .8 gap which worked perfectly for my car above 12psi boost (19psi atm)
tried bosche plugs once.. never again.
thanks yeah ive ended up with bcp6res, and i decided on the -11 as im only upto 9psi atm just have to find a day to do everything now
well that was a bit of a pain in the arse to change... not hard just removing everything. i had trouble getting the coilpack cover back on properly, ended up losing one screw and not able to get one more back on... :S
    • I used to have Walbro 255's when they were a pretty common update. (or were they 044? 040?) In any case I had a dirty tank. I thought the tank was good, but I would find the filter would clog in maybe ~50km of driving. If the issue persists, well, your fuel system or tank has crap in it that the pump is sucking up.
    • Hi. Ok thanks for the info. I/we do not know what tune is on that Nistune ECU so it is why there is stock ECU and that Nistune is for later when the car is done. I have guy who tunes Nistune and other ECU so i will then take it to him to see and properly tune for the car   And for the update. On 99,9% it is bad fuel pump. Which is wierd cuz it is like 2 years old(brand new walbro 255) and that filter (also brand new) was dirty.  I was alwaya pumped premium(100) on very good petrol station so i dont know how is that possible...
    • Dear folks My family members have 4 different cars : Triton 2015 and Corolla 2011 and Mazda3 2012 and Hyundai Elantra 2014 Looking to buy engine oil funnel spill free What I found are are below  https://www.amazon.com/gp/aw/d/B0BBTTJNKX?ref=ppx_pt2_mob_b_prod_image&th=1 https://www.ebay.com.au/itm/145553221359?srsltid=AfmBOoqYBU6Ptw0LU_bAp_k67U3qkF97HHvePkA7iHZw8vUmiwoIRaRr https://www.amazon.com/gp/product/B09X23TCS5?th=1 Is there a funnel with attachment that fits most cars ? Don't mind to spend for a decent quality  Thx
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
