bilsteins out (too firm for what i use the car for, and to be honest the suspension i had before was pretty much perfect, just a little high)
drove it to the drifting
also its running a bit shit at first with the cold mornings, everything runs as normal once the water is over about 60°C
could be the plugs, they are iridiums but i've probably put 60,000 kms on them already :(
I asked about for you but the people i asked hadn't seen you
If you've still got that 3" cat i'll take it Peter
also, the car looks good from a distance, but there are a few problems when you get up close
Edited by pipster11
so when finally get round to changing my rocker cover gasket im gonna change my spark plugs too, ive been reading around and looking on the ngk website they recommend, pfr5g-11, but ive read a lot of people just go with coppers - bkr6eya and im assuming once again -11
would that model in the coppers be the right ones for me? all i have is turbo back, and front mount.
aslo with the rocker cover gasket the half moon, when using gasket glue do you only put it on the curved edge, not flat?
also wanted to go the drifts... damn work
Edited by MatthewT85
http://www.skylinesaustralia.com/forums/topic/104405-spark-plugs/
Yeah sorry I didn't have a chance to catch up with you, I was so busy I didn't even have time to scratch my self! If you're looking for me at a drift event I'm usually at Pit Exit or Race Control ;)
yep thats what i read, just saw they had BKR6EYA and someone else had BCPR6ES
but i think ill just stick to the bkr6eya
BCPR6ES or 7ES's
I've only ever used 6/7's 180-400+ rwkw
ok thanks yeah thats what sorta got me confused between the two, i think i read in there that one 'neck'/bit that sticks into the coilpack is longer....
am i right in putting the gasket glue only on the half moon curved piece? and the rest is fine to leave
thats ok mate
I saw Alan in the commentators booth (rather he saw me)
If you want to bring that 3" cat up to the sprints of whatever is at symmonds this weened i'll gladly take that off your hands, don't think i can do the wheels atm, don't quite have the money for it atm
Don't be fooled into buying anything other than coppers either.
i've always used copper BCP6res NGK plugs in kermit, at approx~25 a set i simply replaced them every 5k when i serviced. they comein 2 types that ive found, if they have 11 on the end they are pre-gapped to 1.1, if they have no numbers, they are generally .8 gap which worked perfectly for my car above 12psi boost (19psi atm)
tried bosche plugs once.. never again.
thanks yeah ive ended up with bcp6res, and i decided on the -11 as im only upto 9psi atm just have to find a day to do everything now
well that was a bit of a pain in the arse to change... not hard just removing everything. i had trouble getting the coilpack cover back on properly, ended up losing one screw and not able to get one more back on... :S
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
    • To re-cap, I bought: https://www.alibaba.com/product-detail/Lsailt-8G-Infiniti-Q50-Q60-2014_1601171829627.html?spm=a2756.trade-list-buyer.0.0.2cd476e9FTIlKE As you can see, if I bought 20 it was $653, but I bought 1 so it was $1,170. I was very tempted to buy 2 and resell 1 at 25% cheaper. @MBS206, I am not sure if they do a Kluger one, here is their list but it might be there under a global model name: http://www.lsailt.com/product/android-interface?page=1 Keep in mind these full android replacements have basically all the bits a phone does (cpu, ram, storage, wifi, bluetooth, usb interfaces) other than a screen (it uses a host), thus the $800+ cost. Android Auto screen mirroring is MUCH cheaper as it's just a cut down shell, input mirroring and output mirroring BTW I also need that "screen off" feature, it is much harder to see wildlife even if a dash is reasonably dark. Both the Fuga and V37 have display off buttons for night use, they just come back on for a second or 3 if you interact with it, eg skip a song.
