this isn't always the case. brake clearance is determined by disk type, particularly in wheels with dish
haha!
I thought I typed that... must have just thought it.
Big brakes would be no good with my wheels (LMX5 - 4-pot Brembos would probably fit, but nothing bigger), but my mates Work wheels (similar dimensions) are fine for 6-pot Endless calipers.
So yes, definitely agree that the design of the wheel plays a more critical role.
Those look pretty similar to my Nismo rims (18x7.5 +40)
They will fit easily.
The only way that they may cause a bit of difficulty is if you have big brakes on the front.
I only have stock brakes so it should hopefully be ok.
No don't do it, they are too narrow and they will sit in way too much. I have 19 x 8.5 +20 offset rims on a S2 Type S Stagea. My car is lowered and I have had no guard rolling and I get no scraping at all.
You should go for at least 8.5 inch rims in about a +20 offset. Here is a pic of how my rims sit
I'm not too fussed if they sit too far in for appearance sakes, as I want aftermarket rims more to dress up the Stagea a little better than stockies. Thanks for the advice though. And your rims look sweet :P
Edited by Hanso
One other thing you should worry about with a large offset like that is that your wheels don't rub on the inside of your guards when you turn your wheels to a full lock for a U-turn or similar.
I'm running 18x8 rims with a +30mm offset off a V35 Skyline, and using 245/40 tyres, and the wheels sit perfectly in the guards - the rear guards needed rolling simply due to the width of tyres I chose to run.
come on boys its gotta be a 9" +30 at a minimum, they fill out the rears perfect without sticking out and fronts they sit in a fair bit, could do with a 10mm or 20mm spacer to look better. My new wheels going on very soon once i get the tyres fitted are 18x10 +20 and they fit perfect on fronts and sit out on the rears but i have a solution for that in the works so should look alright, pics to come :whistling:
example of agressive wheel fitment :laugh: sit the same as my vs-kf
can i ask out of curiosity what wheels you are getting? i LOVE wheels haha
Hey Mike you have commented on previous posts i showed the wheels when i test fitted them a while ago but havent had a chance to chuck good tyres on them so the 33 gtr ones are on at the moment. Heres the only pics i got of them...
coilovers arnt low in the pic of rears as i couldnt be stuffed lowering it at the time so they arnt tucking in as much
here is the 33 gtr ones too, fronts definately need big fat spacers to sit right
^^^ ooo what did you get? :(
because you have an rs4-s you might have fouling issues on the rear depending how low and how much neg camber you run - an 8mm slip on spacer may be required to stop the wheel from rubbing the strut. don't forget that even if it just clears stationary that it will bang the strut over big bumps when the suspension compresses and you get a momentary gain in neg camber
i'd recommend running 235/40's on those wheels up front - might run into guard issues with a 245
my car with 18x9.5+15 up front and 235/40's on lipped guards
here's petes rs4-s with 18x9.5+15 235/40 all round and an 8mm slip on in the rear
Was waiting for your reply! lol
DTM rush in shadow. (Had 18x9.5 Volk GT-N lined up but 1x cracked face = steer clear!)
Went the +15 offset to clear rear strut, 7.5' +38 - 9.5' +15 = 2mm closer to strut?
Test fit Tonight and pics with Ribbons this weekend!!! (Tying the knot)
yep, 2mm closer. just keep an eye on it, the 2 manual stageas that i've seen with similar wheel specs to yours had minor rubbing issues so both had 8mm slip on spacers fitted up
those wheels will look nice - be sure to get pics up.. even of the test fit tonight :(
and congrats on the hitch!
Amazing how a RS4-s just swallows rear offset over the auto model. (rear subframe, knuckles or control arms different?)
the factory manual rear subframe is ~50mm narrower than the auto version (so both 260rs and rs4-s)
So does that mean 10' will fit. Does the strut move in that much?
Anyone got pics of the rear of a RS4 with 18x9 +25
They will sit out a further 5mm from my R34 gtr rims +30
Looking at buying a set of rays GT-c's
10" is achievable with an auto subframe - a 10+22 will sit the same as a 9.5+15. i've lent adam (chef_stagea) one of my sets of wheels with 10+22 rear specs and he needs to run an 8mm floating spacer (effectively making them a 10+14) to stop them fouling the strut because the hub is closer to the strut on a manual subframe
i'd not worry about trying to find pics of a 9+25, as you said it's only 5mm out from a bnr34 item - good luck being able to notice the difference from a photo :P
Looks good, but not sure if I want the rears to hang that far out.
I have no more inner clearance on the rear with the 18x9 +30 I have now.
The new bilsteins (sydneykids) I have in there hit the 245/40/18 tyres. If I lower it any more. currently around 335-340mm. Not happy.
well here's a pic of adams car (260rs) that i mentioned earlier to put in to comparison with the above pics, if it helps at all?
17x9.5+24 17x10+16 (+22 with 8mm spacer) and 225/45's all round
Edited by M I K E
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
