RS4s wheels are 17 x 7.5 +30 I just replaced mine recently. Don't have them anymore as I sold them so I can't be much help on the measurement side of things.
what are you running now and what are your clearances?
If you have a look on page 8 there is some pics of my car there with rims on it. In terms of fitment my guards are standard e.g. no rolling. The front outside edge of the rim is pretty much flush with the guard. The rear is in ever so slightly, maybe 10mm. On the inside I reckon I have close to an inch of clearance from the inside of the wheel to the shock body. The overall height of my wheels is near enough identical to the 215/50/17 inch tyres I had on the car before.
I could have my car alot lower without any clearance issues, I used to have it alot lower on my 17's but i kept scraping the underneath when going into the driveway and over speed humps so I raised it about an inch. Heres a couple of pics
(FYI I run Greddy coilovers so not sure how this would compare to standard struts).
post-39581-1250229527_thumb.jpgpost-39581-1250229603_thumb.jpgpost-39581-1250229643_thumb.jpg
im looking at buying a rs4s and ive got a set of rims in mind that are 19x8 with +35 offset, do you think i'll have issues? or will they sit too far in, eg look crap
it's probably pretty clear by now that my wheel fitement standards are a little more agressive than the majority of you blokes and that by my standards they really will look sunken to all buggery
look at petes white rs4s a few posts back, the wheels you are looking at will sit 39mm in from them :S inner clearance will be about the same
hmmmm
i just looked them up and it appears they will extend out further than the standard rims by an ENTIRE 1mm !!!
but the rims im looking at dont seem to be available in a smaller offset :(
anyone else running on aftermarket wheels that only just extend out or are the same as the standard rims??? .....with pics???
at the moment im looking at either Konig - Hotswap Silver or Vault Crystal, both are 19 x 8 with +35 offset. also considering the vaults in 20 x 8.5 +35 but im not sure if they will foul the strut
i know its been a long three or so years, most certainly glad to be back
i put down a deposit on the new stagea today
Great to hear Andy.
Mikey is going to help me fit something to the yellow pig soon....when they are in stock so if you want to come over and share a beer and wave your hands around and point while I flounder around you are more than welcome.
  • 5 weeks later...
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
