Mine is a 2000 but I highly doubt that would make any difference. If you go back a heap of pages there's a s2 rs4s running 18x10 +15 with coilovers. That's even less clearance than 9.5 +12 and he doesn't seem to have an issue. Maybe pm him?
at this point all i can do it get the wheels here and fit them up, see what happens and fingers crossed.
if they dont fit i will probably ask someone with an RS4S to trial fit on theire car to see whats different.
Good place to start I'd say. And also 235 won't really give you any more clearance than 245. Both are stretched do they'll angle away from the rim edge, but they're both still locked into the rim at the bead which means theoretically they would be the same. Get my point? Just depends on how much stretch and how much road contact you want I guess. Just another thing to think about.
yeah, havnt decided on the tire size yet, all going to depend if i need to run spacers on a wheel which will sit 60 mm out from where im at now and the guard fitment becomes an issue,
a little streatch is good for look sbut i dont want stupidity, eitherway the tire wont be what will contact with the strut.
I have 19x9.5 +12s all 'round, with 245s, 35 profile I think and coilovers on a 99 rs4s.
Perfect guard clearance and a couple of mm on the strut in the rear.
Was pretty sketchy when i ordered them.
Have had them on the car for 20000k now, no dramas....
Mind you, mines not as low as yours, so not as much rear camber pulling the top of the rim in closer.
I had trouble getting standard skyline rims (V35) to fit without spacers to get rego.
I ended up having to use some scabby R32 rims on for rego.
wheels should arrive soon, i was hoping today.
i have been doing some more digging.
firstly:
Can anyone CONFIRM for me the width of the standard R34 GTT 17" wheels
cannot seem to confirm if they are 17X7+40 or 17X7.5+40??
7.5 =]
which means i will be gaining clearance.
also i have been mashing through the 55 page stag suspension thread.
realising i have several degrees of - camber. i am ordering camber arms which will straighten the wheels back up and give more clearence from the strut again so this should be fine, they should fit without spacers.
i hope :ph34r:
It must be the camber you've got because I'm also running 18x9.5 +12's with 245 45's and no issue at all. stock suspension with nismo springs
is that to me?
new wheels noton yet but yes the camber must be my issue at the moment as the current wheels fitted beffore the coilovers went in. camber arms and new wheels this week i hope
yeah sorry i was replying to you ghost. That's interesting to know if i go adjustable suspension later on, that i'll be limited my my wheels. food for thought.
hope you get it all sorted.
OOOOK
test fitted the wheels today and if it does fit its gonna be seriously snug.
ok so outsude fitment is going to be nice
Front
Rear
however as you know im worried about the strut clearance.
fronts clears everything as far as i can tell
the rears are not
remember this is in the air
i cant fit my finger between them.
ok so the camber is the first issue
this WILL be fixed with camber arms
as it is the hub falls 10mm inwards when loaded up
their is NO way these work without spacers with the current camber arms.
im going to need to run no camber and see if it clears over bumps and around corners.
failing that spacers then slight camber into the guards
tires go on soon and camber arms should rock up any day now.
will roll the lips and hope i wont need to pull the inner guards out.
OOOOK
Front
Rear
the rears are not
I came across the same problem i had 245/40/18 tyres on 18x9.5 offset 20 on rs4s rear and once i had the suspension underload the tyres use to scrap the coilovers, you could set the camber to almost no camber at all, but personally it looks too weird for me, so i ended up getting longer nismo wheel studs, spaced out the wheel and getting the camber right and 225/40 tyres..
Edited by shotpointblank
im going 235/40 tires, i really didnt want to go spacers, i really didnt.
hoping i take some caber away and run about -1deg and it wont touch under load.
under load now it gains f**king heaps of camber with the stock arms
im so confused, noone with an RS4S with 18X9.5 +12 has had this little clearance. why mine?
i.e.
Just took a pic of mine for you (sorry it's sideways, uploading from phone and it rotated it). As you can see there's quite a bit of clearance with the stock shocks, I'd say a good 15mm. Obviously BC's are thicker though. I'm not sure how much but you can work that out. Mine is as stated earlier s2 rs4s running 18x9.5 +12 with 245 40's.
Edited by GH05T
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
