Gary with your system you must run a cooler is this correct?? On the 3 or so  GTRs i intitially removed the hicas from I was simply blocking up the rear chamber, and the pumps would die I think due to over heating so I simply make sure I do a 2ws pump conversion at the same time, obviously its not needed if you run the pump the way you suggest!! Plus the 4ws pump is a mammout compared to the r33 pumps running a 2ws pumps looks better in the engine bay I think!!!
I agree, the R33 power steering pump is smaller, lighter and simpler. In an ideal world, it would be worth changing. But, in my opinion, the cost in both time and money is excessive for the benefit gained. Plus it makes it a far more complicated upgrade than simply swapping one hose around.
Most of the guys doing HICAS removal want a simple and quick elimination of the rear steering. Having to change the power steering pump, pulley, hoses and reservoir is a complication that might stop them from doing what is really necessary. ie; removing the HICAS itself.
Later on they can swap the pump etc over if they want, but it isn't necessary for them to get 99% of the benefit. The 1% from swapping the pump can be done later.
:mellow: cheers :(
is it a straight swap? or do you need a little bit of manufacturing to get it to fit?
You will need it's mounting bracket. The banjo fittings are at a different orientation to the 32's. And the pully is a 3-rib (the R32 is a 4-rib)
Anyone wants one, I have one from a Stagea. PM if you are interested.
R32GTR's and R32GTST's have a cooler on the power steering standard.  It is a simple loop of aluminium pipe, but it works.  On the race R32GTST I have used a standard Stagea auto transmission cooler as the power steering cooler.  Works a little better.
:D cheers :blink:
isnt that cooler (tube loop with fins) part of the hicas plumming? so it would cool the fluid running through the hicas. I know they share the same resevouir, but now that the hicas is gone, a lot of the heat will also be gone. So the ps wouldnt get that hot?
I too have a auto trans cooler which i might use instead of the stock cooler, only cause it looks nicer!
thanks
steve
thanks
steve
Hi Steve, I don't know how much total heat the HICAS adds. I reckon maybe none, as what heat it adds would be dissipated by the long run underneath the car in the steel pipework.
All I know is, the first GTR I removed the HICAS on, boiled its power steering fluid at a track day as it had no cooler. Ever since then I have run a cooler on all R32's and not had one problem.
:blink: Cheers :blink:
  • 3 weeks later...
with that being the case am i right then in saying that for a 32 GTR a tomei hicas lock kit is an easier/neater option?
I was going to go the lock bar route and like the idea of the weight saving, but i don't particularly want to fark around with the power steering too much. The tomei kit is a just 2 shims and a little module to cure the warning light/heavy steering problem.
I just used some metal washers to lock the rear rack on my R32 and then the sydneykid power steering mod to make sure the pump didnt poo itself. Worked a treat and cost like 50 cents.
Not sure why people go out and get Hicas lock bars when the factory bar with washers seems to work just fine.
SK - I'm pretty thick so sorry for asking this - which you have probably been asked a million times.. by looping the two lines that WERE going into my HICAS unit - is this running the fluid through the cooler? Cos I really have no idea where this cooler is... and this is how my current setup is going... just looping the lines..
Looping the lines is fine, the rear stage of the pump is just pumping the power steering fluid all the way down to the back solenoid, then back to the front solenoids and through the cooler.
The cooler itself is a simple loop of aluminium pipe, just in front of the radiator on the drivers side.
By doing that you are disconnecting the HICAS OK, but you are not saving the 20kgs or so of weight. That's the only additional advantage of removing the complete system.
:) cheers ;)
i have a question if hicas is there to help cornering why is it so many people want to remove it
about the only thing i have heard is the when taking tight lines the car tries to correct you, then you correct the car, then the car corrects .....
but what ever happened to slightly adjusting your driving style to work with hicas??
tell me if im wrong cause i dont really get it
i own a GTR and will look at doing some club level track days
so why is it better to remove hicas?
RellikZephyr
RellikZephyr
Firsrly HICAS is not there to "help your cornering", HICAS is there to try and make the casr understeer at all times when sdriving at 9/10ths. Nissan designed it that way as it is safer for the Wallies. When they get into trouble the HICAS is supposed to make the car understeer, so instead of spinning off backwards they plough straight ahead. The ploughing action itself reduces the speed, so if they do go off they hit things at a slower speed and the front airbags/seatbelts work. If you spin off backwars/sideways, the airbags and seat belts have less chance of saving the Wally's ass.
Back to your question, you have got it......."when taking lines the car tries to correct you, then you correct the car, then the car corrects........." So instead of a nice smooth line around a corner at 10/10ths, it ends up being a sequence of jerks and corrections. If you are already at max G force, the jerks will cause the car to loose traction completely. So you have slide, correct, slide, correct, this is both detremental to lap times and confidence sapping.
Adjusting your driving style doesn't help, all it means is you have to go slower or suffer the momentary losses of traction. You can't control the car accurately with the throttle or the steering wheel when this sort of stuff is going on.
I have never ever seen a Skyline race car with functioning HICAS, once you have tried it you will understand why.
Hope that clarifies
:O cheers :)
  • 4 weeks later...
Gary - mind if you post a couple of pics of this looping you speak of?
Which looping? There are three possiblities;
1. The loop of aluminium pipe that serves as the standard cooler?
2. The loop where the front solenoids used to be, to feed the fluid through the standard cooler?
3. The loop at the rear to bypass the rack?
I will have to take some pictures of my own car, I don't actually have any, either before or after HICAS removal.
:) cheers :)
As far as I can tell, the loop at the rear is just a bit of U shaped pipe - I can figure how that goes,
Moreso, when you pull out all the associated rear piping, where to hook the remaining rear stage piping up to the aluminium pipe.
So 2, and 3, above :)
Thanks again
what do people think of this solution???
its the tomei kit, but does it cause any problems with the pump in the long run?
http://www.tomei-p.co.jp/_2003web-catalogu...thers_rset.html
As part of the Tomei kit install you disconnect a plug under the bonnet. This in addition to fitting the washers & the small electrical unit. Unfortunately I don't understand all the instructions (They are in Japanese) so don't know exactly what it is you are disconnecting...
Can anyone help?
Used to be very popular, locks the rams on the rear rack in their outwards position. So there is still power steering fluid circulation, but no steering action. The box plugs into the HICAS ECU and stops the dash light from coming on.
Quite effective, no long terms issues, they are just expensive for what they are. Plus they leave all the hardware in place (and even add a little bit) so no weight saving.
:D cheers :D
PS; make sure you get English instructions as they are tricky to fit, particularly the washers.
Edited by Sydneykid
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
