Xenon Hid Lights Conversion For R32
Ronin 09
Putting this here for references/Google searches:
Osram 4000K W5W LED with Philips 85122 bulbs.
Hey Niz,
Are these the exact options you selected for your retrofit?
Loved how yours looked, planning on doing this to my projectors.
Cheers in advance dude.
Yep same projectors and D2S bulb. I used a different ballast (a fast start one from eBay) and made my own harness. Don't need sealant as I used to existing one (just re-melt), but it's probably a good idea to get the sealant if you scraped off the old sealant.
Did you post details on the ballast already? I would be interested - finally going to get the lights sorted (possibly halos). Nice timing with the lesser Aussie dollar which is my loss.
Did you also use an E46 shroud of some sort?
Ah - thought the Morimoto XB35 ballasts were instant on as well? What's burning time to get full output?
Does choosing a more powerfully rated Ballast make a difference to setup? They have the option for Morimoto 50W ballasts - but all I can think of is more efficiency rather than anything truly meaningful.
Anyone here use the Osram Xenarc CBI (5K or maybe 5.5K) - just white and bright apparently. Scared to try because of brightness and the fact that it does cost a fair bit.
No idea of their new stuff, but the old Morimotos weren't quick, took like 15-20 seconds. Build quality is pretty good though.
I'm guessing their newer stuff with the separate igniters make them quicker.
Stick with 35W ballasts, don't need any more than that. The higher wattage ones burns the bulbs brighter (hence burns them out faster).
  • 1 year later...
There is an existing thread for installation of Morimoto Mini D2S 4.0 so I won't go into that, but here's Mini D2S 3.0
Instead of trimming the 'bracket', I'll use a 'spacer', which also will bring the projector slightly forward (a good thing).
Edited by niZmO_Man
images rehosted
  • 1 month later...
  • 1 month later...
Current status of my D2s retrofit:
Are you trying to squeeze that into the R32 headlight body?
If so, I'm bloody impressed and will look awesome if you can make it work.
Sorry this is in an R34, but this was the only update retrofit thread i saw :30_no_mouth:
Can remove if you guys only want this R32 specific
How are people ensuring that the lights are at an appropriate level and not blind other drivers?
Mine looks ok close but steps up when far? Not sure if normal or not?
19553505_1750355104978841_983218819_n.jp
For comparison this is xennons in a jeep:
    • Does this count as a time trial as well? I got all gold in the master super licence (1 lap time trial) and received a McLaren MP4/4 for my trouble.  If anyone else has done this, did you ride the wall right around the first long right hander at Lake Louise snow track to get gold? I couldn't do it any other way... best I could do without riding the was was within 2 tenths of the gold time.
    • I definitely get the low power, sporty car to drive to smash gears but not be doing eleventy million miles an hour! It makes all the normal drives fun!   Rev match tune sounds like the funs! I didn't know the NC had a DBW throttle!   As for me, still have the Skyline, it still has the Barra in it. It's been pushed to the side of the workshop at the moment. Pretty much waiting on me finishing the wiring, and dropping new fuel lines in. Got myself an ACDC Tig end of last year so been teaching myself TIG welding to build a few things for the Skyline. The missus wrote off her GTB liberty at the end of last year, and got it back on salvage rights stupid cheap. It's also still registered, so will mean easier for me to take to the track already done most of the panel damage, just playing "clear the workshop" to make space to pull the motor and box out, fix some oil leaks, replace the clutch, and replace a few minor broken things.  Also got a Lathe at the start of the year, which is adding to the annoyance of no space, which is another reason I'm trying to build things to get more space, to get the Lathe back in a final home for it. It's a BIG lathe, can turn a 355mm diameter, and 1metre between centres... Got it at a steal! So between it and the TIG and old MIG welder, I'll be fabbing some fun little shit up But we've had a lot of shit stuff happening at home, so it's slow going getting things done. But one step at a time!
    • I love Catalunya.  Got a 1:54.632. The AMG is a hoot.
    • I hadn't got that far, my main worry was the connection to the actual calipers themselves. I'm just using new (ish) stock brake lines in the stock setup. I've just had a stud welded to the knuckle that is a little lower than the original stud (so my knuckles have two studs each side) to not have it be stretched so far in previous BBK setups, so the "block" (in the second picture) mounts a little lower for me and I hope I don't need to change anything. I may have even changed the connection to the calipers in the past and have since forgotten I did that. I may not have. Guess how I'm gonna find out. Source: hopium
    • It's more so I'm using the 1x piece line from HEL that goes from the body to the caliper. There's no middle block/mount like the HFM ones or the GKtech ones. There are certain angles/suspension compression where the line actually slightly contacts the ARB. Below of how mine sit (not my photo): How I want it:
