Gb: R33 Gts-t And Gtr And R34 Gtt Radiator Guides
Hey ppls.
As many of you may already know, I seem to be the Radiator guide king.
I've just drawn up the R33 GTR and R33 GTS-T Radiator guides to be made from Aircraft Grade 1.0mm Aluminum.
They will be of the same high quality as my R34 GTT guides and will cost pretty much the same.
I'm bending up the prototypes in the next week or so, but would like to get an idea of numbers of how many people would like them.
The price will be close enough to $80 + Freight, but the more people, the merrier.
SO, Who's in?
R33 GTS-T
2BNVS...........................berkeley nsw 2506..........................PAID
Dezz..............................Hoppers Crossing 3029, Vic.............PAID
bilbo117........................................................................
....Paying Monday
Dynamix
GTS-T V-Spec..........Balcatta, WA 6021.................................PAID
Mavric.....................Melbourne Pick Up.................................PAID
Trust33....................Address Received.................................PAID WITH ANODISING
ZXFIRE....................Sydney, 2170, N.S.W............................PAID
GTRgeoff.................Melbourne Pick Up.................................PAID
Greg.......................Melbourne Pick Up.................................PAID WITH ANODISING[/
Freeman..................Newcastle, 2287, N.S.W........................CONFIRMED
Babia......................Melbourne Pick Up.................................PAID
Sydneykid...............Sydney, NSW, 2234
Deceeve..................Mt.Pritchard, NSW , 2170......................CONFIRMED
wolverine................NSW..................................................PAID
Lordsnipe................West Perth, 6005, W.A.........................PAID
Alpine Stars.............Perth, 6000, W.A
(B1) MR_fanny.........Melbourne Pick Up...............................PAID
Trick x 2..................Hope Valley, SA, 5090.........................CONFIRMED
Total 22
R33 GTR
Cooper....................Morphett Vale SA 5162..........................PAID
Trick........................Hope Valley, SA, 5090...........................CONFIRMED
Total 2
R34 GTT
darn756
woldo......................Kings Park, 3021, VIC, standard Bar.............PAID
Mr Sniper911...........Loxton, 5333, S.A, STD Bar..........................PAID
GT25T.....................cabramatta, 2166, NSW, Nismo Bar..............PAID
kralster...................Victor Harbor, 5211, S.A STD Bar...............PAID
SKY 34.....................Cannington, 6107, W.A BOMEX Bar.............PAID WITH ANODISING
JapanDyno x 10..........Germany, Pick Up when in Aust
HLT4Eva...................Melbourne Pick Up.....................................PAID
Total 16
BASS OUT
  • Replies 520
id be in.... question though, how they normally come with the hole for the bonnet latch can u make one thats flush like no gaps for the latch since i dont have mine anyway?
ben...
Is there a thread or perhaps you can tell me yourself:
What are the benefits of such guides?
Is there a real-world difference?
Is there a quantitative performance increase (eg dyno/400m times)?
Edited by Wink
Okay,
What the air guide does is stops the air from going through your grill and up over the top of your radiator.
It forces air through the radiator and increases the cooling capacity of your radiator.
Also, it looks cool and gives you somewhere to put stickers.
Hey Bass.Do they sit good on aftermarket front bars.
My bar is aftermarket and the headlight is missing the plastic mounts that the stock grille usually sits on.And because of that there really is no place for the front of the deflector to sit.
Would it be easy to make a mount for one of these myself??
answers
They bolt onto the radiator support panel, so there's no real problem with aftermarket front bars.
My experience with the R34 GTT, is that the brs are very similar with only slight differnces between the stock and aftermarket bars.
Nothing a quick blast with an angle grinder or a hand file can't fix.
I have designs currently for R34 GTT with Nismo, stock and aftermarket front bars.
I have designs for R33 GTS-T and GTR
I have not yet got R32 or R31 bars.
These I will look at soon.
Oh, and you need to tell me what model of car you have and whether you have stock or aftermarket front bars.
So like, R33 GTS-T SII stock bar.
or R33 GTR series III stock bar.
Cheers
Pete
what are the differences between your product and the UAS one or are they equivalent?
also, if there is enough interest would you be interested in making a guide that goes the whole length of the engine bay? ie covers the tops of the headlights as well. i'll try and dig up a pic if you're not sure what i mean. it may be too much mucking around to make it though.
Thanks
Greg
Yep, they will be equivalent or better to the UAS. I'll make them as best I can.
Greg. I've thought about making the extended version, but doing it in Aluminum will be very trickey, and difficult/expensive to send. Making it from say FRP or Carbon Fibre isn't what I'm into. Although I know it can be done this way, I'm no expert in it.
There isn't much airflow benefit in doing it that way, but it sure looks good!!
BASS OUT
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
