Gb: R33 Gts-t And Gtr And R34 Gtt Radiator Guides
JimX Funnily enough I have an R33 GTR guide in my office.
I over ordered when somebody cancelled!
I'll take it! How much is it including freight to Sydney? Is it adonized at all? If so what colour? If not, would it be possible to get adonized before sending? If so then at what cost? Have I asked too many questions yet? How about now? Do you hate me yet? How about now?
Sorry, got a little carried away there. PM me your bank details and I'll DD you the cash whether or not it's adonized (although if it's already adonized in hot pink, I may have to re-think the purchase)
  • Replies 520
Jet Dat
Yeah I can make you one, no probs.
thanks heaps mate..i will definately take a r33 GTS-t SII off your hands :wave:
pm me the payment details, i will dd or i can pay on pick up or whatever you like...
is it still possible to get one for a sI r33 bass junky??
ill answer for pete...chances are you'll get 1 mate...as there'll be plenty of them comin back to pete from the guys with series 2's
Hey guys.
Here are the Anoised guides for your viewing pleasure.
I think that next time all guides wil be anodised because the finish is just soooo much better.
BASS OUT
Im lovin the anodised.Got teh hungrys. :D
hey bass got it today looks great! one problem... my bonnet wont shut properly. it will lock half way but wont fully push down lock in. ive got a cf bonnet. i cant see anywhere where it is rubbing. anyone had a similar problem?
Freeman.
The reason it wont close is because the CF bonnet will have the tounge that slots into the latch at the bottom attached to the bonnet with a pair of screws that aren't on the normal bonnet. Those two screws are hitting the guide.
Happened when GTTR34 got a CF bonnet. We have to drill two big holes in the guide to make it fit.
Thats what you'll have to do. And by big, I mean hole saw size.
Get a black texta, mark the bottom of the screws, maybe use grease or oil, or vasoline or something. Then lower the bonnet down.
Lift the bonnet, and you'll see where the screws hit the guide.
get masking tape, and cover the section of the guide where the mark is with masking tape (remove the oil or whatever first of course). The tape should be about 100mm square.
Put the oil or grease back on the screws.
Close bonnet.
When you then see the marks on the tape you know where to hole saw.
The masking tape is there so you scratch the guide less.
Get appropriately sized hole saw.
Cut holes.
Reaffix guide.
Bob is your mothers brother.
okay let me write this down.
Wolverine, Dezz, Azn, lordsnipe all need Series II R33 Guides.
Just Boost it wants one of the Series I R33 Guides.
Wolverine and Just Boost It.
You guys are in the same state and I think really close to each other (only 3 postcode numbers apart) so maybe Wolverine you could give yours to Just Boost It?
Who else has series II that I don't know about or havent mentioned??
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
