Gb: R33 Gts-t And Gtr And R34 Gtt Radiator Guides
  • Replies 520
Hey peeps.
I'll be bringing all the guides that I have to Deca so that anyone was has them on order can pick them up.
I'll make sure to wrap them nice and clean so they don't get damaged.
Heya boys :)
I just recived mine today and it looks great.Cheers bass.
Next time you should go for some speed hole in them to allow for air flow to the stock air boxes in 33's.Just some food for thought.
Mine doesn't shut properly either :D It only hits by about 5-10mm, but enough not to be able to close.
What is the distance meant to be from the left hand edge to the start of the latch cut-out ?
Edited by GTS-t VSPEC
JimX.
Sorry man, the guide was taken to the post office today.
I went away for a week last week, and then was out for another two days Monday Tuesday. It was meant to be taken to the post office by one of my staff, but as the story goes. If you want something done right, you gotta do it yourself.
Series II guides.
Again, haven't been able to do anything yet as I've been away in Syd.
I'll work on them this and next week and should have something to cut by the end of next week.
Sorry for the delay.
I'll be at the Bells hotel tomorrow night, 7pm.
You can pick it up from me or the committee from there then.
Or, somewhere else that you want to meet me.
Sorry it's taken a while. Last few weeks have been crazy.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
