  • Replies 109
just out of curiosity who else makes a similar kit to this? trust with TD-05??
Trust Td06-20g with 10cm rear housing would be about the same but then you need gate and manifold.
Also the td06 is plain bearing, oil cooled only, while the hks kit is ball bearing (think) water and oil cooled. also its newer which means new tech whichs should also mean less lag (hks says the GT pro s, is power and responds)
Cheers Michael :P
thanks for the map
look forward to the other also...
Does look similar... Timing is an issue im trying to deal with atm...
Will be going to mercury in the new year to get it sorted...
Edited by Col-GTSX
If you print this off and goto your ignition map - maybe just write down the differences?
Also had trouble uploading straight from excell so had to print off and scan onto a photo program.
I think I've got a boost leak so am going to make up a couple of bits of pipe - one with a blanked off end and the other with a valve fitting so we can do a pressure test - it really feels like I've got a boost leak.
AFAIK you can buy the dump separately. greenline are a better bet for a reply if you have a query.
i dont think this dump is available separately, it is specific to the 2835 turbo/kit. is it not?
that is correct :P
HKS make dump pipes for Stock R20/25 Turbo Flange, they also sell a GT dump pipe but that is only for EVO's and Sr no rb (and its still a stock setup dump pipe just comes with a hks front pipe)
If you think im wrong check the HKS website under extenstion
Got the car dynoed on a different dyno yesterday afternoon - no changes just a modern dyno dynamics dyno in shootout mode.
The 341.9 horsepower - in kw is 255rwkw - sounds much better than the 275 rwhp figure from the other dyno.
Interestingly the AFR's were reading differently between the units - the original tune was done with a motec and the tuner was tuning to afr's around 12.8 - 13.1 which I thought was lean - yesterday with the autronic lambda unit it was reading rich at 10.9 - 11.3 at full load.
We tried pulling a bit of fuel out but it lost power, then tried putting 1 degree of timing in - too much knock, then tried pulling out a degree of timing out and lost 20 hp.
The motec unit must read lean as at cruise with the o2 sensor switched on it was reading about 15.8, whereas the Autronic was reading 14.7 which is about right.
We didn't muck around with it - I just wanted to do a few power runs to get a dyno readout from a different dyno.
10 kw less thasn you sly 33 - I don't have a catch can though and have the stock airbox with k&n flat panel filter.
Cheers!
damn thats a nice power figure. I only managed 218rwkw with a GT30r and 470nm or torque I think. Torque was there but lat in the rev range (5k)
Here is my ignition map - (95 ron fuel) anyone wanna post theirs up to compare to mine?
timing.htm
would one of these hks 2835 pro's be to big for an rb20, would i see full boost by 4000-4500 rpm??
I don't think the unit is too big for a rb20. Physically it's not much bigger than the stock rb25 unit - probably similar to a gcg hi flow. You should see full boost by 4000. I can get 18 psi at 3000 - when I have access to a scanner in a few days I'll post up the data sheet from the dyno dynamics dyno - the power run was from 2500 rpm to 7000 and at 2500 it had about 16 psi. The print out shows intake temp, boost, speed and AFR's from memory.
I haven't been in any other rb25's with turbo upgrades but I can say the car goes seriously fast now - you can overtake in fifth no worries, 4th is quick and 3rd you have to be thinking quick and hang on!
Cheers
Yes it's done in silver. We made up the steel cover plates so they wouldn't coat the inside of the housing BUT they pulled the covers off and did the housing inside and out...?
Had the cat off the other day and noticed some tiny specs of the coating in it (smaller than a grain of sand) - the outside of the housing is fine though.
Just were a bit worried of what affect the bits of coating would have on the exhaust wheel but I guess we'll find out eh? Really hope it just gets blown out.
The coating cost about 70 dollars but if they are going to do the inside make sure they are going to do it in the more expensive black coating. This stuff comes apart at 750 degrees and you will most likely see 800.
We've been told it's basically impossible to get the stuff off once applied - even when sandblasting it just bounces off.
Cheers
excellent turbo kit, my results here:
http://www.skylinesaustralia.com/forums/in...4entry1487384
I need to spend more time on the dyno to get it up there, I am not 100% happy with the current tune. The adjustable actuator really confused the tuner, and couldnt be bothered to adjust it.
Cheers
cool, thats not too expensive then.
Do you think there will be any increased boost response due to more heat being retained? or is it just to insulate the engine bay from getting too hot?
Cheers.
    • What 1.5 way? There's no such thing really as a 1.5 way, just different ways of explaining 2 ways with different ramp rates. HOWEVER. In any driving in a straight line your 1.5 or 2 or 1.7 way should have no clunking at all. With the clutch fully depressed the diff should be silent (unless it's welded but I'm assuming it's not). Something aint right here.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
