  • Replies 155
Posted Images
Another excellent caliper painting thread here:
http://www.skylinesaustralia.com/forums/in...p;hl=duplicolor
The paint schmiddy suggests is absolutely brilliant. Avoid VHT like the plague and use what schmiddy says. :)
good guide, but my main suggestion would be do not do it with the callipers on the car, and definately not with the wheels on the car. no matter how carefull you are there will be overspray. plus you really dont want to be painting them with pads and rotors, suspension etc all around. spend a little extra time and remove the calipers. :ninja:
good guide, but my main suggestion would be do not do it with the callipers on the car, and definately not with the wheels on the car. no matter how carefull you are there will be overspray. plus you really dont want to be painting them with pads and rotors, suspension etc all around. spend a little extra time and remove the calipers. :D
How would one remove the calipers? Hard? Easy? Someone (if they have time) post up a tut on caliper removing? Thanks!
takes 5minutes...
- remove rims
- pull out wire clips from caliper
- remove 1 pin
- remove backing plate (prevents it flicking out)
- remove 2nd pin
- remove pads and shim plates
- undo 17mm (i think) nuts around the back.
- banjo bolts for brake line (make sure to have an empty bottle nearby to put the bolt in.
  • 2 months later...
to remove calipers ther are two 17mm bolts on the back us a 1/2 inch breaker with small extention crack it then use ur ratchet to take off. dont let the caliper swing on the brake hose..
the front su can turn the hub. get a rattlegun in ther and do it that way.. well u can on toyotas.. :(
i reckomend a die grinder to etch out NISSAN after u painted over it.. :(
Better than a die grinder is a piece of wet and dry and a cork block.
Just rub the paint back until you get a nice shiney "nissan"
But be careful, one touch of your nice fresh paint will piss you right off :D
  • 3 months later...
Yep,
Get yourself some Wet and Dry, quite fine grade.
Also, get cork or wooden block.
Wrap wet and dry around the wooden block and carefully sand back the paint.
This is exactly how I did it to mine. The Nissan come up looking brushed and it really makes the calipers look great.
i just removed wheel .. covered hub in news paper and wheel arches and side of car and sprayed in my garage with no wind ..
make sure u tape correctly and make sure you get all the paint off if you didnt mask the disc could smell funny or cause irregular braking which you obviously dont want
I used a wire brush on a drill.Went right back to bare metal.
The paint was great and still is quite good.the rears are pretty much as anodised red as they were when they were first done.though the fronts are faded due to track days and instead of being anodised red they have faded slightly.but still resemble the red colour.i will post up before and now shots tomorrow.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
