oh and manages13 my block and head machining has taken over 23 weeks alone (NO assembly at all) thanks to those involved
shit brad the company i have been using will offen do the same day drop off and pickup if i prebook a week or so out B)
DUDE that is one nice list i only cringe at what it must of cost to put together as i know how much it cost for me to get my build together. Can i ask who you are using for the build and tune? and when you might have it on the road?
pete
  • Replies 315
Thats definitely a dream setup.
Very nice pics.
With regards to the rb30det thing.. I think the biggest concern is the height. One big advantage of the 2.7 kits from japland.
But revability... Its got everything to do with gearing and how well the hotside flows. The VL's run a 3.45:1, run that in your Stagea and it too will feel like a big diesel. :(
Edited by Cubes
pete
tuning will be at Racetorque im 99% sure on. they mainly do race cars, and keep quiet in the performance scene in perth. been highly reccomended by another gtr owner with autronics and over 550rwhp.
the build is all done at home, machining hassles where through a few well respected perth shops but failed to show reliability and the shops told me 3 weeks for the block MAX and 2 weeks for head MAX. well im still waiting on the head which has been 12 weeks and the block was 11 weeks :angry:
PM me if u want the name of the shops i used for machining, as i dont want to upset the moderators :)
cost, hmm well im not gonna announce that here, bit over original budget though :lol:
should be in the car by xmas and run-in/tuned by end of january pretty definately. depending on the tuner :)
cheers
Brad
Is anyone else touching themselves looking at those pics?
Adrian
Yes i did...
Wow whats a setup i am jealous...
I think you have done the right thing with the 2.7 kit...
3 litre kits belong in R31's......
Hands down to you Brad, very nice job on your build - all top quality parts there. I'm sure you'll get power with reliability with all that gear.
Good luck with the build and keep us dated on the progress.
thanx guys, well im picking the head up tommorow finally, BUT it isnt assembled as i need shims for the valve springs, cause apparantly the JUN cams are regrind and have a smaller base circle.
so they aint even billet like HKS ones and are regrind from GTR cams. (thats the words of the shop doin the work).
so ive decided we will assemble the head as well, with the help of my uncle who usually does drag engines. shims will be arriving monday next week supposedly.
pretty pissed about the cams but, thought JUN was better than that? B)
does smaller base circle mean they are not as good in making power as a set of hks normal base circle size ones with same degrees and lift?
cheers
Brad
They weren't able to machine up shims?!?!?
The reason for the smaller base circle is to allow for a higher lift without or with very little head modification.
Tomei also uses this method to squeeze out a little more lift.
Edited by Cubes
no they said the largest shims they had were not big enough and they needed "special" ones made or some shit. sounds like an excuse to charge a shit load of $$$ for f**k all :) gotta be custom made and specially heat treated or something they said.
i took the head off the shop cause they have had it 13-14 weeks to do porting and reassemble, so they ported it and wait till now to check the cams and whether shims r needed and now they delay it another week, plus assembly time. so i told em to not bother and i will do it.
Dont mean to burst your bubble but make sure you get it tuned by a reputable tuner. We tuned a 500hp built 930 Porche TT over here on the Gold Coast. It had been tuned by some guru in Perth that used all of about 5 of 200 available features of an autronic. The car was that rich that it had washed the bores!!!!
I was going to say give Greg at proengines a call about shims, he reshimmed my head and it was a pain in the ass but he got it spot on, with no bullshit. He has posted above me though, so thats obviously where he got the shims from ;)
cheers
Brad
Hi Brad, all of the Jun cams I have seen are billets. They have to use a smaller base circle to get the lift, RB cylinder heads don't have enough room. The Jun instructions and web site both quote the following for all lifts over 10.5 mm;
Clearance of head for cam lobe rotation required.
Special valve spring required.
Special valve retainer required.
The "Special valve retainer required" means the cam has a different (ie; smaller) base circle to standard.
:) cheers :D
There seems to be a few people that are having trouble with machine work being done on their engines, either they are very slow or not done correctly.
Greg at Proengines posts here on the SAU and the work he has done for me has been nothing but exceptional and in a timely fashion. Won't go anywhere else now.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
