  • Replies 100
Posted Images
lol new Zeds = the crap old school Zeds = Nice :)
the old VG30 single cam single turbo motors in the old Zeds have more power then the quad cam twin turbo motors in the 90 models B)
CLASSIC NOT PLASTIC!!!!!!
:lol: :lol: :lol:
OK guys i must admit, i got extremely pissed one night and when i got back, noticed my housemate Zor was logged in on the forum.
Couldnt resist having a laff...
Completely forgot doing it until my mate just came across this thread!
Soz man... :)
I'll never do it again... (sober)
First of all....why would you buy a car that weighs like 2 tonne, they are renowned for blowing heater hoses under the inlet manifold, you can't change the turbos on them without basically removing the engine - which takes around 18hours on a hoist, they have no balls coz the car weighs so much, they look like a boat, they drive like a boat, the bottom end is nothing to run home to mum about and they are way too overpriced for the overall package. WTF?? I know a guy who owns two and he has had the worst headache since buying them coz they always need repair and they cost a fortune. The labour charge is like 2-3 times more because everything takes that much longer to repair on them.
I don't care if they are Nissan's, they are no son of mine. I have disowned them.
END RANT.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
