hey, my one of my headlights looks like it is turning a yellowish sorta colour., but its on the inside, right now its not very noticable, but it is slowly expanding....
anyone know how i can stop this thing from spreading? and how to remove whats already there?
thanks
https://www.sau.com.au/forums/topic/99826-r34-gtt-headlights/
hmm... i remember someone ages ago with a 33 taking the headlights off and putting the plastic into some sort of solution which cleared it up like nothing else... i think it might be a matter of taking the clear plastic off and cleaning it with something.
tried running a search through these forums for something related to this?
mine did it too. i had to take my light apart and clean the inside. It was ball breaking, but my car looks brand new now. well worth the hastled, just make sure you set a whole day aside.
i unbolted the light. and separated the clear plastic from the rest of the light assembly using a hairdryer. cleaned the inside of the plastic using brasso (which works Shmiko by the way even on the outside). Then resealed it using windscreen silicon just incase i ever have to do it again.
mine arent that bad, so far its only the top section, ie eyelids for the lights would hid it,
i will buy some of that product and use it this weekend
thanks everyone for your help
Any cance of you running me through pulling the light apart? My drivers side light is completly fogged and I didnt want to damage it while taking it apart.
cheers
do repco and supercheap etc sell this plastx stuff or is it a special stuff from elsewherre
It should be readily available from autobarn. I looked in a few supercheaps but they've had to order it in. Ive had my car 18 months and the one bottle is still going cos you dont use much at a time.
cheers
1)the front bar needs to come off to ge to the two bolts underneath the light.
2)Once that is done their are about 5 bolts holding the light in. Unlbolt them disconnect all the electric cabling powering the headlights.
3)remove metal pins holing clear plastic cover on then use a hair dryer set on hot hold it 15cm away from plastic
4) slowly pull the light apart prying it carfeully with a spatula(same as one you would use when filling cracks before painting a wall)
5)clean clear plastic using brasso. rub on let it dry and polish. wash out iwth water
6)once it is apart clean out all the black silicon from the section where the plastic sits inside the black surround so when you glue it together again it bonds properly.
7)put small amount of windscreen silicon into area which you have cleaned out and put clear light cover back on push together and replace metal clips. i suggest letting it sit for as long as possible then puttig it back on say at least 6 hrs later.
Hope that helps. it isnt really that hard just time consuming.
please note. some r34 gtt's have had the oem xenon kit cut out of the bottom. if this is the case with yours make sure you cover the section that has been cut and glued back with the windscreen silicon and let dry. This can let moisture in and discolour the clear plastic.
Thanks mate ill do that
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
