  • Replies 118
who owns the r33 with the kit? that ran heaps shit, was doin high n mid 14's
isn't that pretty normal for a stock 33???
any bitch that says shit about me like that when I go out... quick bitchslap to the face for you! lol
how long are the waiting lines now to get a decent run in?
Normally there is around 160 cars racing over a period of 4 hours, last time I took my FPV GT-P I got 8 runs in...But
Like these guyz were saying, they only got 3 runs, just depends, thats why Private track days are awesome, cost a lot more but last private day I was at, people were doing 38 runs and that included brake's inbetween...
I will be heading out there this comming wednesday i think the 11/01/2006 anyone else heading out?
I will be racing the HG Prem this time! going for low 12's
