Id say due to the upgrade the address path has changed slightly.
Instead of being
http://www.skylinesaustralia.com/forums/SBC-ID-III-AVC-t62408.html
its now
http://www.skylinesaustralia.com/forums/topic/62408-sbc-id-iii-vs-avc-r/
A quick search should bring the new one up anyway until someone feels like adjusting all the links
Instead of being
http://www.skylinesa...AVC-t62408.html
its now
http://www.skylinesa...d-iii-vs-avc-r/
can you do it or does it have to be a moderator? I have no idea what you are talking about but it would be good to have all the info available again!
Just remember, we take no responsibility to what you do you your car.
GENERAL
Australian Stagea Part Dealers
External Stagea Web Links
Stagea Parts List
Stagea Dyno Results
GLOSSARY OF TERMS
The C34 Buyers Guide
What do I need to do to my car before a track day?
Getting It Off The Line
FYI: Insurance for your stagea
SERVICING
DIY: Stagea 5000km Service
FYI: Air Regulator Maintenance
DIY: RB25DET: Changing the Spark Plugs
DIY: Changing the Oxygen Sensor, Lambda Sensor, O2 sensor, etc etc etc.
ECU
FYI: Series 2 (R34) ECU pinouts
FYI: copgy Backs
M35 ECU Fault Codes
ENGINE
RB26DET Conversion Tutaorial
DIY: RB25DET High Boost mode with standard solenoid
DIY: Adj Camshaft Pulley & New Cam Belt
DIY: Stagea Air Deflector
DIY: Oil Cooler Installation
FYI: Aftermarket Fuel Rails( thanks to SK)
Updates On The Jun 2.7l Staj Build
FYI: Max Hp Out Of Standard Rb25
FYI: Max Power Out Of Neo
How To: RB26 conversion
DIY: 5min $5 Intake Pipe Mod For Your Stagea/skyline.
TURBO
TUTORIAL - Guide To Selecting The Right Turbo
FAQ: Stagea Turbo Upgrading
DYI: Jaycar Boost and Fuel Control
FAQ: Turbo Timer Install.
FYI: SBC ID III vs AVC-R
EXHAUST
FAQ: Stagea Exhaust
FAQ: Split Dump Pipe
INTERCOOLER
FAQ: Stagea Intercooler
DIY: R34GTT Intercooler into Stagea
DIY: Water Spray For Aftermarket Intercooler
FYI: Check Your L/h Inner Guard Intercooler Exit
FYI: Intake Temp Cooling Options.
TRANSMISSION + DIFF
C34 Stagea CV Joint (and Boot) removal/replacement (and part numbers)
FYI: Stagea gear ratio's
DIY: Transmission Cooler
FAQ: Automatic Trans Thread
FYI: Stagea Diff - Is It Wearing Out - Replace With?
FYI: out goes the stagea diff in goes the GTR diff
DIY: Running your Stagea in RWD mode
FYI: Manual Conversion Checklist
DIY: Auto to Manual Conversion Guide - SAU
FYI: Why NOT to convert auto to manual + some manul conversion info
DIY: Stagea Auto Troubleshooting
DIY: How to SAFELY convert your AWD Stagea to RWD (for dyno days, etc.)...
BRAKES + WHEELS
Stagea Brake FAQ
DIY: Anodize your brake calipers
DIY: How To Paint Your Standard Brake Calipers
DIY: Stop your brakes squealing 101
FAQ: Stagea Wheel Dimensions
DIY: Stagea brake upgrade using R33 GTSt calipers and discs.
DIY: Painting your wheels tutorial
BODY
Car Care Prescription (detailing)
FAQ: Stagea Body Kits
DIY: Front Bar Removal
FYI Front Glass Tint
FAQ: Replacement windscreens
Tow Bars for Stageas
FAQ: Insuring your Stagea
FAQ: Alarm for your Stagea
DIY: Rear Taillights
DIY: Headlight Bulb Replacement
Stagea Bonnet Gas Struts
INTERIOR
DIY: Stagea Headunit/stereo Removal
FAQ: Stagea Floormat
FYI: Nismo Key
How to Adjust your Window Close Hieght
How to replace/install LED dash globes.
How to replace/install LED Climate Control globes.
How to remove and replace your air-conditioning filters.
I need a beer after that
  • Like 1
hey none of techos links work they just go to the homw page , wtf
thats what the 6 previous posts to yours say...see my above post for the fixed links
there were 2 that i've removed as one was a duplicate and another i just couldn't get to work on an external site.
  • 1 month later...
  • 4 months later...
Hey there,
Excuse me if I missed it but do you have a tutorial on reseting TPS after cleaning the throttle body on a VQ25DET?
My Stagea is idling too low & cutting out on hard stops or (sometimes) during parking. I figured cleaning the throttle body & Idle Control would be a good start but I'm concerned I may not be able to reset the 'fly by wire' system. I have heard they can be a pain.
Cheers in advance!
Hi Lisa,
Yes, your on to the right direction. Other thing to look for is any vacuum leaks, letting in air to the plenum. You're correct that it can be a pain, best not touch the plate itself, just spray around it. I have no idea if it actually affects anything, but I'm careful opening it this way and that. You'll see a build up of black gunk on the back side of the plate, which causes it to stick and not come back to idle after decelleration.
Here is a link to the reset- timing is critical:
http://www.nicoclub.com/archives/g35-how-to-reset-ecu-throttle-pedal-release-idle-air-volume-learning.html
failing that- it can be reset using CONSULT III at a dealer.($)
Welcome to the site, and enjoy your stay :)
Thanks for the link. Awesome info to know!
I cleaned out the throttle body (without moving the butterfly) & what a difference. I now idle at 600RPM instead of 430RPM & the pick up is MUCH better. No stalling either (yet...touch wood).
Cheers for the welcome :)
  • 7 months later...
Hi everyone,
I've got a Nissan Stagea 250 RX Four and the brake light atop the tailgate is not lighting when brakes are applied. Does anyone know how to replace the bulb if it has failed, or otherwise remove the entire unit if it needs replacing?
Thanks in advance for some assistance
  • 6 months later...
Considering the RWD M35's aren't allowed into the country in Australia, I doubt there would be much info floating about. I would say it's very close in most aspects to the G35 in the states. What info were you after exactly Garry?
Except for vq35de ones :P
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
    • It's TWO steering wheels actually. 😛 one for each hand They are wheels, and they steer!
