  • Replies 160
Posted Images
Aarons times dont count, he is master cheaterererer :D
1:08s is getting there. Were you happy with how the car ran? Think you got a feel for whats left inthe car?
And im goign to be giving you a huge points start, as it looks like i will be in Singapore until mid June
I've still got your brake fluid in the car from Sandown. That's my secret. Don't tell anyone though...
Aaron did a 1:02.6 in only 2 sessions, I got a 1:04.5..... Was hoping to get a 1:07, so I'm stoked....
Awesome fun!!! Can't get enough of it......
Bring on PI next month!!!!!
Well done Matt, good to see you car has the GO aswell as the SHOW!!!
Time are up already?!?!!
http://www.racetime.com.au/?event=c0602&e=g03&view=fastest
Yeah pretty happy with the car, can do some more work on the suspension setup, the problem is I can't safely run more boost with the standard bottom end... there is more left in the car :( i reckon i can do better than 1:08.. I'll be back in October to have another crack.
Jack you kicked arse out there.. sounded tuff!! See you at P.I. B)
Aaron I want your car!!! that thing is nutz. *droool* cheater :D
Well Done to Jack would have gone better dude but you were getting held up in some of the sessions. my dodgey phone watch said you laped 1.05 in the 3rd session.
Sorry we had to leave early but some mates were going out and i wanted to tag along.
Well dont matt car looks mint and sounds awesome, awesome times for a first crack
LOL, now i know you are lying...i was actually using that Motul bottle as a hip flask to fool the officials. I will not be held responsible for where you poured my Glenfiddich :P
Way to go Jack whatever happened to you takign it easy? Times suggest you have lost the plot and driving the wheels off the thing :(
Poor odl Chris will have to stick with the DECA days as it seems the power stakes are getting too high for the std turb fellas
FERNI, if you are reading this...you on track with the new engine, or are you giving the car a rest for a while. Semis on you thing will mean you will be stepping up to the plate as well :(
Ppl dont rate Calder, but like it as its good fr really having to get stuck into the brakes and getting the power down.
The times by Matt and Wayne are good for the RWD boys...i just hope i can keep up with the R33 boys. I have a few mods in the pipeline which i hope will make the car quicker, but i still havent got the best out of my existing setup so dont want to throw it on until i get the max out of the car as it stands...so, Matt what power are you running, i need to do some calcs ;)
Troy, I've discovered that my car can do wonderful things when pushed hard without fear!!!!!
On a serious note its just that I have more confidence in the car than I did last year, especially with the RE55's, the more I push it the more it grips!!! Calder was a good test in regards to braking points, I can confirm my slotted rotors are no longer slotted!!! There are also large cracks going from outside to the inner part of the rotor, so basically they are getting thrown out....
I also have an exhaust leak, my car sounds like a tractor, I'm assuming it has a crack in the front pipe, as I'm using standard cast manifolds.....
Oh well, that's motorsport for ya!!! Worth it in the end!!!
Bring on PI!!!!!
JAGR33 one of the standard cast manifolds will have cracked, those things always crack. Would be unlucky if its the front pipe. From what I saw of you and your car things looked to be going well, very impressive to watch!
MSPEC - From what I hear its the stainless manifolds that crack not the cast ones, so I'm assuming its the front pipe coz its stainless..... Thanks for the compliment, ur car sounded pretty horn on the straight!!!! The problems started on my last supersprint...
Roy - looking at getting just new rotors for now, but new brake setup has crossed my mind!!!! Frank had family commitments so couldn't attend, not sure about the deal between Aaron and Snowy??
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
