  • Replies 717
Hey Adam (Abo Bob)
As u well know mate the engine is KAPOOT >_< So I aint gonna be going anywhere with the Cefiro.... So scratch me from the lineup :huh:
But i will be back for the next one...with some SERIOUS Cefiro POWAH :D:)
BIGGER , BADDER , CEFIRO POWER ahahahahaha :yes:
Does anyone mind if i bring my mate and his magna??? He wants to see what it does
I'm sure he's more than welcome to give it a go on the dyno.
It'd be nice to see some other cars dynoed apart from Skylines!
With so many coming and me being such an SAU event n00b, I'd need everyone to wear nametags with the online nick printed on them :O
"Hi, my name is cowie165" :P
maybe a good idea.
I have only ever met about 5 ppl from the sdu days
Adam, I'm pretty certain I'll be along and running the Stagea (assuming they'll still be doing the "pull the driveshafts, remove/replace clutch slave cylinder" thing). Either way, I'll be along for a look and meet & greet during the day.
I think my cousin is coming down from the Central Coast in his s1 R33, but I doubt he'll be running his car as he has a PowerFC, but it hasn't been tuned beyond the self-learning stages yet.
Cheers,
Nick T.
Sounds interestingand coool.. might take my fully stock-ass R33 and see how it does. So I can use the test as some-sort of benchmark as someone in here suggested.
Never dynoed it before. Havent seen some of you guys for awhile aswell. How big is this place? assuming it will accomadate everyone hopefully. If I dont dyno Ill watch everyone else rip it. :D
:mad:
Pretty big set up and big dyno room with multi screens and big car park and not too many other cars on a Saturday especially in the afternoon. Lunch shop right next door normally closes at 12 but will stay open longer as plenty of customers to buy V Drinks. Should be a fun and interesting day for all.
Turbo Smart will be there with new product we have been working on with them and will be testing and showing as well as other suppliers. Also new M110 Fuel to test before and after etc.
Also contacted HPI and Zoom mags.
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
