1992 r32 gtst
std internals rb20det
std injectors and ecu
garrett ball bearing t04 turbo with internal w/gate
hybrid fmic
3" mandrel bent custom exhaust from the turbo back
de-cat pipe
turbosmart gated bleed valve
HKS pod filter
alum. pre-turbo intake pipe
oil catch can
gtr fuel pump
made 232.2 rwkw at 18 psi
since that dyno i have added a malpassi rising rate fuel pressure reg. but yet to check results
Edited by lagmonsta32
1992 r32 gtst
hybrid fmic
de-cat pipe
HKS pod filter
oil catch can
gtr fuel pump
Hey buddy, going off your results maybe my dyno sheet was correct?
My run Down:
1993 r32 gtst
ball bearing VG30 turbo
hybrid fmic
bleed valve
pod filter
walbro fuel pump
Adjustable FPR
made 221 rwkw at 16 psi
(i thought it was too much power for small mods i had)
Here you go Roy, dyno sheet.
not 100% happy with the curve, it could probably get brought on a lot better with fine tuning etc. BUT it does feel awesome through the hills!!!
Nissan Cefiro
RB24DET - Tomei pistons / tomei rings / tomei 1.2 HG / rb25 crank and rods i think (or rb26)
HKS 2530 / screamer pipe with straight pipe through to twin flutes at rear / Power FC / Gizzmo IBC / GTR injectors / Z32 AFM / walbro pump / GTspec FMIC / K&N filters / Motul oil / oil cooler
240rwkw @ 1.17 BAR
Edited by huddy
-R32 GTS-T 1993 RB20DET
-STOCK INTERNALS
-STOCK COMP & INJECTORS
-3.25INCH STRAIGHT THROUGH ZORST
-FMIC 600 - 300 - 75
-HYBRID TURBO 57 COMP - 63 ZORST INTERNALY GATED
-APEXI SAFC II
-EARTHING KIT
-Dyno results 151.4rwkw running 8.7psi at 5400rpm injectors maxed out and run was aborted
-will fit gtr injectors, sard regulator, bosch or walbro fuel pump and start turnin up the boost
to somthing that people don't laugh about
  • 4 weeks later...
1990 R32 GTS-t - 47,500kms
RB25 S2 turbo
Monsta FMIC (cheapest I could find)
GTR pump
3" turbo back
Blitz DSBC
Pod
Z32 AFM (not needed yet, but it's on there for later)
Remapped
182rwkw at 6600rpm on 14psi
Full boost by 3300rpm
Made a bit more power before (186rwkw) but did a few consecutive runs to iron something out and everything got a bit hot.
Edited by salad
184 rwkw untuned on 1 bar at turbo tune today
rb20det
4inch zorst
aluminium intake
nismo reg
hks ebc
hks pod
std turbo
fmic
then remapped by speedlabs only made 176 as my 185 was unsafe lol
go the stok turbo haha ( must be stok turbo record )
dont have scanner to put chart up !
'92' R32 GTS-T 123,000kms
Mods list:
Custom inlet plenum with belmouthed runners
Q45 90mm infinity throttlebody
Series 5 550 cc injectors
Gtr fmic
Gen111 5.7ltr fuel pump
Apexi power fc
Apexi avc-r
Apexi intake pod (mounted in fron bar)..... shithouse in the wet - great in the dry
custom s/s highmount exhaust manifold
custom s/s dump pipe with bellows for heat expansion
Garrett 3540 turbo
Tial 38mm external gate
S/S exhaust
Z32 afm
S13 RB20DET Silvia
3" High flow exhaust with split front/dump pipe.
STOCK RB25 S1 Turbo
Hybrid FMIC
R32 GTR Fuel Pump
Platinum NGK spark plugs
Remapped STOCK ECU (Tuned by Yavuz @ Unigroup Engineering) made 199.5 rwkw! :P:P
3rd gear looses traction on boost in a straight line! haha love it... GO THE RB20's!
Edited by s13rb20det
'91 R32 RB20DET 85.000kms
Stock Internals
Stock Injectors
Stock Computer
Stock RB25 S1 Turbo
3" full exhaust/screamer
FMIC
POD
HKS EBC
040 pump
Sard Fuel regulator
189.2 @ 1.1 bar (boostworx)
Edited by Richo
1993 R32 Skyline
RB20DET
Stock internals
5-speed manual
R33 S1 turbo
Trust front mount intercooler
Full exhaust (Split 3' dump/front pipe)
GTR fuel pump
Boost controller at 14psi
Re-mapped ECU
Air pod
Dyno'd at Tilbrooks Auto & Dyno
193 rwkw
AFR: 11
Edited by lows_13
R32 Skyline - RB20DET
Sliding Performance RB25 Hiflow for RB20
RB20 turbo wastegate
BOS importing split dump/front pipe, 3" meatalcat, 3" stainless catback
TRUST tube and fin FMIC
GTR 444cc injectors
GTR fuel pump
Remapped factory ECU by me :)
turbotech boost controller
NGK copper plugs gapped to 0.8
Splitfire coilpacks
Splitfire panel filter
Stock cams, airbox, BOV,
18PSI non shootout mode done in 4th gear on 30deg day
if you look at the sheet the scaling from rpm starts at 800rpm??? so the ramp rate looks ridiculous. didn't notice till after i left the workshop :P pretty happy with the results. it made 241rwkw a few weeks earlier but i cant find the sheet. Might put a exhaust cam gear on and see if i can get it to come on boost earlier.
  • 3 weeks later...
stock rb20 det
fwd faceing plenum
custome high mount turbo
38mm external gate
vlt3 exhaust housing t4b front cover 56mm comp wheel[built by myself]
std injectors
modded std computer
8300rpm limmiter
boost cut
speed cut
3''mandrell bent exhaust no mufflers no cat
made [email protected] degree day 40 in the shed!!!non shoot out mode
450*300*80 cooler
sorry no pics tuned by TOTAL AUTOS IN HUONVILLE HOBART TAS
Stock RB20DET
Highflow R33 Turbo
GTR Front Mount
Apexi SAFC II
Bosch 040
Standard Injectors
Malpassi Adjustable FPR
Apexi Pod
3" Turboback Exhaust by Desynz
Cooler Piping by Desynz
Manual Boost Controller
Tuned By FIST Performance
264HP on 14PSI
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
