After 30 mins of messing around with the new ecu, this setup exactly the same as below, results;
401 kw atw, 24 psi (will go to 30psi), 6300rpm only (out of 9500rpm), maxed out injectors. Too much crank signal noise to continue, external crank trigger needed before going back to the dyno.
Torque is massive as you'd expect, here's a quick vid http://www.youtube.com/watch?v=QCkm6174AbA
Tune finished, external crank trigger not working as it should so revs go to 8000 instead of 9000, timing is all set now;
  • 1 month later...
my engine has just been finished being modified, goes in the car monday and my 1st event with the car back in power play in brisbane in 2 weeks.
Engine
RB30/26 "3064cc"
Tomie oil pump
Custom crank girdle
chrome olly main caps
CP Pistons
SPOOL Rods
ARP main studs
ARP head Studs
Modified bearing caps
Lightened and balanced crank
Ported head
+1mm oversize valves
270/270 camshafts
valve springs & titanium retainers
Oil Cooler
ATI 1000hp harmonic balancer
S13 Power Steering pump
Nismo engine mounts
Hypertune 90mm Inlet Manifold and Throttle Body
6 x 1000cc Inj's
Custom Fuel Rail
600x300x65mm thick Intercooler HKS s type
6Boost Manifold
Turbo smart Gate
GCG T04Z Turbo
HKS dragger Exhaust system
Exedy twin plate clutch - 1000hp rated
PAR gearbox 1st thru 5th
Standard Tailshaft
Engine
RB30/26 "3064cc"
Tomie oil pump
Custom crank girdle
CP Pistons
SPOOL Rods
ARP main studs
ARP head Studs
Ported head
270/270 camshafts
Oil Cooler
Nismo engine mounts
6 x 1000cc Inj's
Custom Fuel Rail
6Boost Manifold
Turbo smart Gate
GCG T04Z Turbo
Standard Tailshaft
  • 3 weeks later...
Hello this is my first tune on my new motor.
It's a RB30/25 Neo
standard valve's, valve springs, cams, rods, crank
Power FC
Ross/ACL forged non turbo +.20MM pistons
Seimens 660cc injectors
Z32 AFM
Hypergear GT3576 56T.82 turbine and .60 comp internally gated with a 1.5KG high pressure actautor
It needs a bit more of a tweak, as I used a oiled filter and clogged the AFM but never realised untill after it was tuned.
Cam gear,tighten up the A/F ratio and some decent ducting between the intercooler and radiator as it was getting warm on the dyno.
It may not have MASSIVE power but it is wicked fun to drive.
chris
Mercury Motorsport custom design rb26/30
RB30/26 "3064cc"
Tomie oil pump
Custom crank girdle
Chrome molly main caps
CP Pistons
SPOOL Rods
ARP main studs
ARP head Studs
Ported head
270/270 camshafts
Oil Cooler
Nismo engine mounts
PWR oil cooler
PWR power steering cooler
6 x 1000cc Inj's
Custom Fuel Rail
6Boost Manifold
Turbo smart Gate
GCG T04Z Turbo
4inch dump, 3.5icnh after the diff and a 3 inch muffler Exhaust system
Standard Tailshaft
524.3hp on 19.5psi limit set at 7100rpm, pump fuel
Edited by GOT04
  • 1 month later...
RB26/30 DET
CP forged 86.5mm pistons
Spool rods
GT3582 1.06 rear housing
Turbosmart 50 mm race port wastegate
Greddy type r BOV
Greddy RB25 FMIC
3.5" dump to 3" cat back
6Boost manifold
Sard FPR
Sard 800cc injectors
SARD Fuel Rail
Bosch 044
Standard plenum and TB's
OS Giken TS2CD Twin plate clutch
Rb25 gearbox
ARP head and main bolts
Link G4 ECU
376 KW on the rears at 18PSI, although boost is now set at low at 15PSI and 330KW. the engine was leaning out due to lack of fuel, so now back to saving up for a surge tank and external pumps.
Car drives better now than when it was a simple RB25 - Sweet!
  • 3 weeks later...
RB31DETT
HKS GTRS's
JUN Cams
PFC
ARC FMIC (big one)
twin 3" to single 4" to 5" exhaust
and other tricks
716hp-534kw @ 20psi
No injectors or fuel flow left. Will add another pump and get it happening
  • 1 month later...
this is how i bought it and it shat its self not too long after this.... ;) but everything happens for a reason .. right.....
R33 gtst series1
RB30/25
Tomei & Hks cams
Link ecu
FMIC
HKS pod filter
stock exhaust manifild 3.5'' mandrel bend exhaust with high flow'd cat =) (screamer pipe, love it)
T04B with a .8 rear housing
splitfire coils
sard pro fuel pressure reg
Nismo 740cc injectors, unknown brand but very noisy fuel pump (read as big enough)
HKS adjustable cam gears (still set at 0' lazy bloody tuners!!!)
Balanced & Collard crank
Jun oil pump
stock pistons which were 7.1-1 and stock rods
Greddy style inlet manifold
bla bla bla, the list gets boring after this..
but she made the best part of 350rwkw at this point.
when its finished getting built i'll post again with the new... but it should be alot better than what it was!! :)
  • 4 weeks later...
Put my car back on the dyno last night to check out new cams...
Forged RB30 bottom end
RB25 head with 256 poncams
GT35R (0.82r) + 6Boost
550cc, aftermarket intake etc.
KEAS fully manual/built RE4031A, 4500rpm stall
398rwhp @ 17psi
Makes peak power @ 7500rpm
didnt bother touching the adj. gears as this is enough power with the auto for now. 11.3 AFRs and I think it was around 15 deg timing up top.
Is good fun. Cams made a rediculous difference, makes 70rwhp more through entire rev range, and makes power through to 7500 (rev limit, power was still climbing).
  • 3 weeks later...
My R33
Turbowerx 25/30
Wiseco Pistons
Spool Rods
Custom Grind Sure Cams
Valve Springs
1600cc Injectors
Twin half inch fuel lines.
Microtech
42r
List Goes on
Blew Turbo Gasket that's why so laggy on that run.
Edited by Buddah
  • 2 months later...
RB26/30 forged bottom end
Cleaned up 26 head
JUN 272's/10.5mm, and matching springs/retainers, stock valves (3-angle grind)
injectors, intercooler, pump and VIPEC (all usual stuff)
Stock exhaust manifolds, ports matcheed to HKS 2530's
320kw, 600nM at 17psi. Boost solenoid would not allow anymore boost.
Will try again soon with new boost solenoid, more/external fuel pumps and maybe splitfires to replace stock coils.
  • 1 month later...
  • 2 months later...
26/30
PowerFC
044 intank pump
RB26 head, light port, decked, CC'd chambers, performance springs, standard valves, stem seals, seat pressures etc etc
Tomei 260, 9.1 cams
Adjustable gears
OEM fuel rail
Siemens 870cc injectors
Turbosmart FPR- (have SARD not fitted)
Cometic 1.2mm HG
86mm ACL pistons 20though over 9.0:1 comp ratio
Spool rods
GTR plenum and throttles.
Head Restrictors and enlargend oil returns
Block x-rayed, decked and internally painted, welsh plugs etc
ARP head bolts
ACL bearings
Crank polished and grub screwed
Ross balancer
N1 oil & standard water pump
Jun crank collar cryo treated
Enlarged sump
Splitfire coils
Garrett 2560-5 turbo's
Xforce dumps
Tuned length front pipes, 3inch to cat, 3.5 from cat
Assembled with loving care!
6psi 260ish hp
Small update.
Not sure what the issue is, combination of cam timing too far and something else we are yet to find.
Lots of torque, great to drive, but clearly falling over very quickly.
  • 1 month later...
  • 2 months later...
Since the tune below, have put in a mac solenoid valve to allow proper boost, as well as an external surge tank and used the existing tomei in-tank as a lifter pump and twin detchwerks 300lph pumps in teh sard surge tank.
Final result at the dyno day of 387 kw at the treads at 22 psi.
Cleaned up 26 head
  • 1 month later...
RB 25/30
JE forged pistons
spool conrods
rb26 bearings with annular groove
nitto oil pump
tomei pon cams with adjustable cam gears
i port matched and tidied up the head and manifolds
the intakes were ported slightly larger by lewis engines
plazmaman plenum
china spec 100mm cooler
gt35r 0.82 with a 44mm tial wastegate mounted off the turbo exhaust manifold
6boost top mounted manifold
lewis engines drift sump
ross drift harmonic balancer
9:1 compression
22psi made 496.7 on pump 98
The setup was focused towards reponse moreso than max top end power making full boost by approximately 3400. On the dyno day when the boost started dropping off in the top end i rememebered i still only had the 7psi wastegate spring in from the run in tune. Will be going back shortly with the water/meth kit installed and a gtx35r to hopefully shoot for the 400rwkw mark and hopefully produce a good comparison of the two turbos.
Edited by jarrod83
RB30 bottom end
ARP head studs
ARP rod bolts
Stock rb25 headgasket
R32 RB25DE head
Precision 6262 .58 T4 undivided
Deatschwerks 740cc
Z32 MAF
LS2/truck coilpacks
Same side entry vertical flow intercooler
This thing is running PIG rich; when I got in there it wouldnt even register on the sniffer (<10:1). I should have tuned that out beforehand. I pulled some fuel and it went from 350 to 370 HP and it still didnt even register on the sniffer. With more fuel pull/timing add 400 rwhp is certainly possible. Not bad for the JB 6262. I'm impressed. The only downside is the .58 rear is choking it above 5800. Operator let off at 6500.
Original project here:
http://forums.780tuners.com/showthread.php?118785-My-RB30-240sx-project
  • 1 month later...
RB2530 - Cefiro
R33 head - No Vct
rebuilt with new guides, stem seals, cam tunnels line bored etc.
Stock springs, valves and ports.
270dur 8.8lift rb20 camshafts
Adj cam gears, dialled in at home, didnt get touched up on the dyno.
ARP headstuds, cometic headgasket
Modified oil drains with extra oil drain/ breather off the rear.
Bottom end:
Crank assembly balanced
oil pump collar
N1 oil pump with JPC gears.
cheapie water pump.
Ross balancer
Nissan main stud bolts
spool rods w/ arp fastners
mahle 8.5 pistons
NPC clutch and flywheel
oil restictors in block.
Other parts:
Cheap intercooler
greddy "style" inlet manifold with q45 TB
powertune exh manifold.
IHI C7 turbo (basically a old apexi RX6), unknown specs, has a largish rear.
Trust wastegate.
22psi, pump fuel
  • 1 month later...
Parts
R32 RB25DE head
RB30 Series 2 bottom end
RB26/30 CP Pistons 9:1 Static CR (CP pins, rings etc.)
Spool RB30 Rods to suit. ARP fasteners
ACL Race series bearings to suit above rods
Standard Crank. Blueprinted/Balanced/Crack tested etc
RB25DET Series II Oil Pump with extended drive "Snout" (Spool Imports)
GT3076R 0.82 A/R Garret Turbocharger (Standard oil/water lines)
Stiffer valve springs (unsure of brand)
High Energy Style Sump + Head drain (big f**k off fitting on the back of the head)
Standard valve train (RB20DET) (Cams/gears/lifters etc)
Cometic Head gasket (Spool Imports)
GTR Waterpump
550cc Bosch EV14 Injectors
Nismo Fuel Reg (Adj.)
Nismo Engine Mounts/G-Box Mounts
Bosch 040 Fuel Pump
Nistune ECU Remap
Labour
Bore/Hone Block to suit CP Pistons
Deck Block
Grind/Blueprint Crankshaft
Balance Pistons
Micropolish Crankshaft
Balance Motor
Reconditioned Head
Modify/Weld/Machine Head
281 RWKW @ 18 PSI (High Boost)
251 RWKW @ 14 PSI (Low Boost)
img-301131610-0001.pdf
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
