  • Replies 178
The preview post window has gone completely?
I liked this feature as it made browsing forums so much quicker.
Is it possible for individuals to have this option back on, like it is off by default but I can have it?
also is it able to filter text from images?
The whole thing is running great for me, except for my pm sent folder.
Zip file uploads in the SAU Gallery are completely b0rked. When it reaches the photo processing stage it shows completely random photos (and sometime no photos at all). Hitting process gives pages of errors, before the wrong images (and/or blanks) are inserted in to your gallery.
  • 4 weeks later...
Hey
Can you please fix the problem with attaching photos asap. Man I have tried everything to attach a photo which in the past never has any problems doing. The website seems completely borked!!!! when its comes to attaching a photo file of meg or so.
Please help me
[email protected]
cheers
sum advice SysLink67 u shouldnt put ur email address in forums uncoded due to bots looking the net for address's that thay can spam mail too
it would look like this
BB CODE
[ [email protected]]email me![ /email]
with out spaces after [
**EDIT**
little seach on Trawler Bot
Trawler Bot Google
Edited by Madaz
  • 3 months later...
  • 2 months later...
I don't have the new skin or logo :P
Someone logged in using my pc and the new skin and logo appeared.. but when I logged back in as me, it went back to the old skin/logo...
I've looked in my controls but can't find anything there :dry:
and the skin selector doesn't have anything in the drop down menu :)
I'm using firefox 1.5.07
Hmmm, I use firefox too and dont have that problem.
I changed your skin though. Your account was iffy though, you had a different display name from your login name which I fixed.
PM me if you have any other issues.
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
