Funny you mention that Harry, i just PMed Darren regarding each of his cars at the Gatton Sprints so i hope he doesn't mind me posting up this excerpt:
"Yeah 37.6 is my best in the GTR, I've only run the Onevia on 215/45/17 Feddy's and it ran 40 flat or there abouts on those, 180SX would be around the same times as GTR on proper semi's but not any quicker seeing as it wouldn't get off the line as hard but would handle better."
I'm not sure exactly what each of his cars have done, i just asked him for a quick summary.
I'm not aiming to win these things, but i'd love to be competitive, say in the top 15-20%. I think i'd be more satisfied being at the top of my class than having a fractionally faster overall time, but being lower in my class.
  • Replies 46
Posted Images
snagged one so far
Yeah, cause everyone loves a smart arse. Read the post again - you didn't snag anyone.
I can't believe I am about to advocate anything other than a GT-R, but the following costs may prove to be illuminating:
4x255/40/17 RE55's at about $1500 total. May last a season depending on how many events you will do.
Brakes at $250 for a new set of front pads & fluids.
Suspension for about $3500 for springs/shocks/sway bars/alignment bushes.
HICAS locker say $200.
In this form you will have a reasonably competitive GT-R but the total is some $5k. Given the disparity in pricing between that & an S13 you will get alot more (competitive) bang for your buck in a Silvia that a Skyline. Can't believe I just said that.
A GT-R will be ahead on a hill climb, mostly because of its better launch & better torque. Bulk hp is very handy in getting up hills. On tight circuits a well sorted S13 will shine, however on a longer circuit a GT-R should take the silverwear.
At the end of the day there is only one winner & usually it is someone with a large wallet, a very quick car or something dedicated to circuit work. If you look to the class structures lately there are a lot of people running GT-R's/WRX's/Evo's & the numbers in class tend to be larger than in the sports car class. So for in class competition get a GT-R.
Failing that, can I suggest a Westfield of some description - cheap as chips to run, competitive in an outright sense & well scary becasue you are exposed to the elements & your backside is about 150mm off the ground. Driving a GT-R after that feels like swanning about in a limo!
Well i did see a clubman with a s6 13BT engine and running gear on my105 :P but i'm 29,900 short.
Thanks for the advice, its exactly what i'm after so keep it coming!
Fatz may have been ranting, but i dont disagree with the crust of what he is saying.
At 250rwkws, a Silvia is going to be a very quick car. It wont need huge brakes, it wont need big $$$ spent anywhere to be quick.
A few of the Sydney guys may remember a white Series II S14 that had Alcon brakes, Recaro seat etc that use to run at the Motoconcepts days. Well that was my friends old 200SX, and with around 230-240rwkws on semi slicks, GAB suspension and the usual bolt ons it did 1:46s at Eastern Creek. It was a well sorted car and damn quick for what it was. I doubt too many R32 GTRs of similar value woudl get anywhere near it...
The quick silvias are about 2 sec slower than the qucik GTRs at Wakefield (1.08 vs 1.06).
But my point is, it doesn't matter how much quicker a GTR is if it spends most of its life in the garage because you can't afford the rebuild.
The GTRs doing 1:06s though, are they std turb cars or 300rwkws cars?
Someone will always be able to do something cheaper then you, get a better buy then yoiu, flat out drive better then you. But typically i would think a 20k S13 would be quicker around a track then a 20k GTR??????
Ummm, actually im not even sure thats the case, i have a gut feeling the 20k GTR will odds on grenade before the 20k S13
yeah for sure I am talking medium - highly modified cars, otherwise as you know they are doing 1.10 and 1.12 respectively :D
Anyway, I stick with my advice you get the most go and track time for your money with a 32 gtst with a big motor.
So taking that example from Wakefield a highly modded s13 would run around 1.08 and a stock to mild GTR would do around 1.08 to 1.10? I'd be happy with that.
I understand where you're coming from with the rb25/30 r32 gtst but i don't have the time or patience to go through with another project car. If i could buy one already done then i'd consider it.
best of both world slip a stock gtr motor into a silvia for 280rwkw
then you can have the fun and the rebuild cost
shame you ant run a silvia in improved prodution with a gtr motor
then you would have a competitive car
dam you 4 -6 cylinder conversions
Um Neil if you aren't afraid of the dark side ie rotaries, this RX-7 is for sale. The owner competes in hill climbs, sprints, kharna's etc over here & usually wins his class and is thereabouts for outright honours. The car goes hard & is much cheaper than even an S13. Having seen it is is very well engineered the fuel system alone is a work of art) and has that angry bridgeport rotary noise that will piss your neighbours off no end.
http://ausrotary.dntinternet.com/forums/vi...5466&highlight=
I'm not really keen on a GTST, i really like the size and nimbleness of a silvia but then i've never had a modified GTST. Costs would still be higher though because of the extra weight over a silvia, 6 cyl, less aftermarket parts availability.
Neil, what did you think of the rotary?
When I chose the R32GTST for Improved Production I looked at Silvias and found very little weight difference. Without any drastic weight reduction, mine is at 1,220 kgs (plus driver) down from 1,260 kgs when it was standard. That's not a lot heavier than a similarly trimmed 200SX S14, with adequate brakes, wheels and tyres. I figured the better front suspension design and superior standard brakes were a good starting point, plus the 6 cylinder engine upgrades were endless in their possibilities.
All we have to do is get rid of the damn turbo inlet restrictors and we will be in with a chance.
:) cheers :P
I love crushing dreams! R32gtst is not IPRA eligible.
I think there has been a rulign allowing them to run, ditto the S13s etc
What about a $20K R32GTST?
:P cheers :P
I suppose it depends on where you spend your money...my 40k R32 GTST is abucket of sh1t :dry:
Its nice, but doesn't really suit street driving as much as the other 2 and i've really got no experience with rotaries compared to nissans.
The s14 is the heaviest of the silvia series, and does have better standard brakes, suspension and wheel track than the s13, but prices are pretty high also. The s13 is around 1120kg standard, and its pretty easy to get them down towards 1000kg. I'm not sure why the GTST doesn't appeal to me, i guess i'd sooner just stick with the GTR.
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
