God damn reading this thread goes around and around in circles.
We need a summary.
This is basically it.
I have fixed the spewing oil everywhere problem on my RB30/25 and based on my experience this is what I would do on an RB26:
Fit 1.0mm oil restrictor. Drill out oil returns to 10mm and relieve all oil returns. Fit Mines baffle kits to cam covers.
Install 2 fittings to sump as high as possible run one hose to the top (this is a pressure relief - may also blow some oil) of an at least 2L catch can and the other to the bottom (as a drain). Also vent your cam covers to this catch can (should be very little comes out of them). Then instead of a filter on top of the catch can run a pipe to either another catch can or an oil/air separator and what comes out of that should be fine to pipe into the turbo intake - or if you prefer to a couple of LARGE airfilters. This should deal to your problems (don't bother with fitting on back of head). The second catch can will need to be emptied but not very often.
Also (not directly related) minimum baffle kit for sump - better large capacity sump - better still accusump.
The things I would add are as follows:
Good oil control starts with good blowby control. If you have alot of gas there is no way the oil will return from the head of your motor.
I am going with a 1.25 oil restrictor on my next motor.
Having an oil return from the catch can is excellent but a one way valve is a really good idea.
Make sure the size of the holes in the sump are reasonable - tempted to say atleast -12 but maybe -10 is enough.
Not massively convinced by the Mines covers.
I lived with an engine bay covered in oil for way too long, We tried 57 different varietys of catch cans, drains, one way valves etc in my 25/30 to no avail, Even tried the pump from the catch can draining oil back to the sump, It was semi successful at best.
Leak down tests were always good but it became the bane of my life, a couple of hot laps and we would strike more oil than the caltex refinery.
The answer is already in these pages but its damn simple.
parts required.
RB 26 tappet covers
Mines baffles
catch can
-12 braid or equivelent internal diameter lines from the covers to the can
25 covers are an inefficient desing and too small, the 26 covers have a larger capacity and with the mines baffles are a way better design,
the -12 size lines are a must. -10 with only a small amount of oil in the line completely blocks and then just starts a continuous flow of oil hydraulicing in to the can.
The larger diameter of the -12 doesnt fill with oil and even if some does go in the line it doesnt completely block allowing the sump to still vent past any oil in the line.
I doubt anybody has pumped more oil in to their engine bay than I have over the last 2/3 years and i still havnt gotten used to the idea it doesnt happen anymore. first thing I do after a hard run is pop the bonnet looking to see how much oil I've splashed around but there is none. zip, zilch, zero. Not even in the can itself.
In the grand scheme of things its not an expensive fix, particularly for those already wearing 26 covers.
For the 25 blokes the 26 covers bolt straight on so grab a set and gitrdone.
  • Like 1
parts required.
RB 26 tappet covers
Mines baffles
catch can
I have RB26 rocker covers, mines baffles, a very effective catch can and -16 from the covers to the can...
Still have issues, I get around 300ml going into the catch can every 60 odd sec lap
...and there's your problem. 60 second lap. slow the F down...
  • Like 2
Apologies if this has already been covered!
I am looking to install a Tomei Oil Pump and I believe it flows more than the other aftermarket pumps listed in the table on page 2.
The car is primarily street, and will be taken to the track occassionally.
Engine is RB26 so has solid lifters.
Would I be right in thinking that a 1mm restrictor would be the best compromise?
Thanks for the reply. My question was regarding what size restrictor to run to account for the increased flow of the Tomei.
Being solid lifters I understand not much oil is required. So would that justify me using a 1mm restrictor in conjunction with a Tomei pump? Or should I stick with a 1.25 or a 1.5mm?
Even at the lowest setting on the Tomei I believe that they flow more than any other pump listed in the table, primarily due to the larger gears.
  • 1 month later...
Sorry if this has been covered. I've been through a few pages here and there and found a few catch can diagrams but does anyone an mspaint flow diagram of the best/recommended catch can setup (that most agree on after 51 pages :P)?
Thanks guys.
Don't do MSpaint but can do English. IF you have an oil control problem apart from the other measures here is what to do catch can wise: Run 2 half inch hoses from as high as possible in the sump on the inlet side to a catch can mounted at battery level - one hose to the top and the other to the bottom (for a drain so include an optional one way valve). You can combine the hoses from the cam covers and run them into the same catch can (ideally a well baffled catch can). Do not vent the catch can to atmosphere but run a hose from the top of the can to the turbo inlet. Ideally you would include an air/oil separator in that line or alternatively a second catch can although neither may be strictly necessary if you are not getting oil in the line to the turbo inlet.
Thanks guys.
  • Like 1
I agree with the above.
This is my pretty picture I just made. With the hoses coming from the rockers you can either do two hoses if you have enough inlets on your catch can or or like Kiwi says you can run one hose (on mine I joined the two together with a tee piece and ran one hose off the middle outlet of the tee to the catch can.
  • Like 1
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
