HR31-PASSAGE Posted June 21, 2014 Share Posted June 21, 2014 2x2mm I believe Link to comment https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page/59/#findComment-7318164 Share on other sites More sharing options...
BoostdR Posted June 21, 2014 Share Posted June 21, 2014 Work out the % of increased flow in your oil pump over standard and reduce the restrictor size by the same amount if not slightly more if you rev it. There is a fluid flow vs pressure vs hole diameter formula you will need. Plenty of online support. Thicker oil will reduce flow. Another patch is a scavenger pump from head to sump. Works fine. Plenty of OEM cars use this method. VDO do a specific pump. Matt Link to comment https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page/59/#findComment-7318186 Share on other sites More sharing options...
BoostdR Posted June 21, 2014 Share Posted June 21, 2014 Other than that. Don't run your breather to vac. Go atmo if you have a MAP sensor. Vac encourages the oil to stay in the head. Provent do a catch can that regulates pressure to keep less of a differential from head to sump encouraging flow back down. Link to comment https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page/59/#findComment-7318189 Share on other sites More sharing options...
KiwiRS4T Posted June 21, 2014 Share Posted June 21, 2014 & I've read heaps of pages & couldn't find anything The answers are all in the thread. If you get it wrong you could blow your engine. I could spell out what to do but your next question could (and should be) "why?". .. and then I would have to re-type miles of stuff that I and others have already contributed. You need not only to know what to do but to know why you are doing it so that you are happy with your decisions. Probably the last third of the thread should give you the picture and in fact there is a summary of the important points towards the end somewhere. I suspect that you are too lazy to read it properly but if you genuinely have a comprehension problem (difficulty understanding what you have read) I apologise. In that case send me a PM and I will PM you some info. Link to comment https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page/59/#findComment-7318195 Share on other sites More sharing options...
n_D Posted August 21, 2014 Share Posted August 21, 2014 (edited) Can someone confirm my setup, fairly sure im on track but good to get feed back. Goes like this I have both inlet and exhaust rocker covers venting to a 3 port catch can. The third port is routed to the turbo intake so it will be under vacuum. I have retained the line from inlet manifold to pcv to inlet rocker. So whilst motor is under vacuum its pulling air out of rockers through the intake manifold. When its under boost PCV shuts and pulls air through the turbo Its a neo motor so oil restrictors should already be in check. Cheers regarding picture, line to turbo is not hooked up and i realise thats heater hose lol was just dummy fitting Edited August 21, 2014 by n_D Link to comment https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page/59/#findComment-7370687 Share on other sites More sharing options...
89CAL Posted August 21, 2014 Share Posted August 21, 2014 Can someone confirm my setup, fairly sure im on track but good to get feed back. Goes like this I have both inlet and exhaust rocker covers venting to a 3 port catch can. The third port is routed to the turbo intake so it will be under vacuum. I have retained the line from inlet manifold to pcv to inlet rocker. So whilst motor is under vacuum its pulling air out of rockers through the intake manifold. When its under boost PCV shuts and pulls air through the turbo Its a neo motor so oil restrictors should already be in check. Cheers regarding picture, line to turbo is not hooked up and i realise thats heater hose lol was just dummy fitting Sounds like how I have mine setup and I have no issues Link to comment https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page/59/#findComment-7370833 Share on other sites More sharing options...
SiR_RB Posted August 23, 2014 Share Posted August 23, 2014 Hey guys My setup is: Both cam covers going to catch can with -10 lines Blocked PCV Catch can vents to atmo Has other usual oil mods like reimax gears, oil restrictor (think 1.1mm) mines cam cover baffles, oil cooler etc Now my catch can has another -10 thread welded onto it that has a rubber cap over it and not in use, should I run this somewhere? I hear people run a seperate line from can to dipstick when giving the car a thrashin? Does that just basically act as a breather and helps oil flow back down the head? Link to comment https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page/59/#findComment-7372587 Share on other sites More sharing options...
89CAL Posted August 23, 2014 Share Posted August 23, 2014 Really depends where the spare -10 fitting is on the catch can (top, bottom etc) Link to comment https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page/59/#findComment-7372634 Share on other sites More sharing options...
33SOM Posted August 27, 2014 Share Posted August 27, 2014 (edited) Is 2 lines from the sump to the catch can really needed? Surely the one drain line won't be full of oil all the time and would act as a vent? Edit: Also looking at this can unless someone can recommend a better can? Edited August 27, 2014 by 33SOM Link to comment https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page/59/#findComment-7375256 Share on other sites More sharing options...
fatz Posted August 27, 2014 Share Posted August 27, 2014 depends on how used your engine is two is always better than one Link to comment https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page/59/#findComment-7375322 Share on other sites More sharing options...
33SOM Posted August 27, 2014 Share Posted August 27, 2014 Engine is about to be built. Link to comment https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page/59/#findComment-7375366 Share on other sites More sharing options...
KiwiRS4T Posted August 27, 2014 Share Posted August 27, 2014 Is 2 lines from the sump to the catch can really needed? Surely the one drain line won't be full of oil all the time and would act as a vent? Edit: Also looking at this can unless someone can recommend a better can? Will it fit your car? Looks good but don't you know a local fabricator who could make you one for about half the price? Link to comment https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page/59/#findComment-7375410 Share on other sites More sharing options...
R_34 Posted August 27, 2014 Share Posted August 27, 2014 I had my first track day with my RB20 last friday. My catch can is fairly simple : there is only two line going from the two rocker cover to the empty catch can which is vented to atmosphere. Wrecker RB20 with stock internal, highflow turbo, 12psi/0.8b, 444cc injectors, Z32 AFM on standard S13 airbox with a cold feed, FMIC, FFP, STD RB26 oil pump RB25 filter support modded to accept a CA18 oil to water cooler and a 19 row oil cooler. Standard clutch fan and 2 row 32mm copper radiator. I run 5w30 valvoline synpower oil. The weather was ideal, it was a sunny day with 20~25°C. The catch can didn't spill any drop of oil, no overheating and I stopped trashing the engine when the oil passed 120°C. I could run for 15 min (~8/9 lap) or so before stopping because of oil temperature. I could run the engine 100% per cent during the session with plenty 8000 rpm shifting without dramas. My main problem was the power steering reservoir which was spilling fluid way to close to the turbo. Time to install a cooler on the power steering circuit. Link to comment https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page/59/#findComment-7375536 Share on other sites More sharing options...
XKLABA Posted August 27, 2014 Share Posted August 27, 2014 Will it fit your car? Looks good but don't you know a local fabricator who could make you one for about half the price?I just bought the R33/34 one from them for near double that ( but my one has the washer bottle as part of it ) and worth it for the non hassle off designing and fabracating, they are also not just an empty can they are baffled with SS gauze to actually catch the oil vapours I have a AN-12 running from factory oil return on RB30 to the bung I between the two 26 manifolds and a AN-16 running from block to Walsh/frost plug at rest of head on hot side I have a AN-12 running from cold side of block to oil cap and one as a return from front catch can with one way valve A catch can that sits on engine attached to the two cam cover breathers which I put a baffle plate into the two AN-12 line from that to the Hi Octane catch can up front then two AN-12 lines one back to the PCV and the other to the inlet of rear turbo The block returns where drilled to 9mm and head to 10mm and the back returns die ground smooth Will know if it works on the 22nd of September Link to comment https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page/59/#findComment-7375541 Share on other sites More sharing options...
33SOM Posted August 28, 2014 Share Posted August 28, 2014 Will it fit your car? Looks good but don't you know a local fabricator who could make you one for about half the price? Sorry my profile needed updating.. Car is a 32gtr. I have emailed Hi Octane and asked if they could put in another -10 outlet while its being made. Cheers Link to comment https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page/59/#findComment-7375767 Share on other sites More sharing options...
XKLABA Posted August 28, 2014 Share Posted August 28, 2014 I got the return changed to -12 and an extra -12 up top for an extra $20, they where very happy to do what I wanted Link to comment https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page/59/#findComment-7376202 Share on other sites More sharing options...
33SOM Posted August 28, 2014 Share Posted August 28, 2014 I got the return changed to -12 and an extra -12 up top for an extra $20, they where very happy to do what I wanted Hmm I got quoted $30 for an extra -10 up the top. Oh well as long as it works Link to comment https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page/59/#findComment-7376205 Share on other sites More sharing options...
XKLABA Posted August 28, 2014 Share Posted August 28, 2014 I went in there in person and turned out I knew one of them so maybe that got me a $10 discount lol I had a look inside mine with the flexi camera and it should work well PS they have a kickarse collection of 80s BMX race bikes Link to comment https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page/59/#findComment-7376213 Share on other sites More sharing options...
33SOM Posted August 28, 2014 Share Posted August 28, 2014 I went in there in person and turned out I knew one of them so maybe that got me a $10 discount lol I had a look inside mine with the flexi camera and it should work well PS they have a kickarse collection of 80s BMX race bikes Ah ok. I was happy with the $30 anyway. Plus free postage so all good Link to comment https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page/59/#findComment-7376216 Share on other sites More sharing options...
fatz Posted August 30, 2014 Share Posted August 30, 2014 I had my first track day with my RB20 last friday. My catch can is fairly simple : there is only two line going from the two rocker cover to the empty catch can which is vented to atmosphere. Wrecker RB20 with stock internal, highflow turbo, 12psi/0.8b, 444cc injectors, Z32 AFM on standard S13 airbox with a cold feed, FMIC, FFP, STD RB26 oil pump RB25 filter support modded to accept a CA18 oil to water cooler and a 19 row oil cooler. Standard clutch fan and 2 row 32mm copper radiator. I run 5w30 valvoline synpower oil. The weather was ideal, it was a sunny day with 20~25°C. The catch can didn't spill any drop of oil, no overheating and I stopped trashing the engine when the oil passed 120°C. I could run for 15 min (~8/9 lap) or so before stopping because of oil temperature. I could run the engine 100% per cent during the session with plenty 8000 rpm shifting without dramas. My main problem was the power steering reservoir which was spilling fluid way to close to the turbo. Time to install a cooler on the power steering circuit. rb20 dont have the problem Link to comment https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page/59/#findComment-7378589 Share on other sites More sharing options...
