If your numbers are all the same except for one cylinder the chances are you have a problem with that one cylinder - ie #6.  So yeah have another go at a compression test but dont be surprised if you have an issue particularly if it is spitting oil.
Edited by djr81
3 hours ago, -S- said:
So i hesitated to post due to no backed up facts but anyway I just did a compression test and these were the numbers. Stock motor.
P1 - 200
P2 - 200
P3 - 200
P4 - 190
P5 - 220
P6 - 190
And I'm still filling up my catch can easily. .. can i conclude that its just too much oil to the head? Initially i was worried it was due to piston rings ... any thoughts on this? But I'm sure glad the numbers were ok...
What do you mean filling up the catch can easily? You mean with normal driving or on the track?
If you have broken rings on one cylinder that will do it. Try another compression test and preferably a leakdown test.
Yes filled the can on hard driving. .. man... this sucks... i guess I'll try another compression test else where or order the kit and do it myself. .. :(
You just need a cheap gauge. Does it blow the dipstick out?
http://www.ebay.com.au/itm/Nice-Portable-Auto-Motor-Engine-Cylinder-Pressure-Gauge-Tool-Compression-Tester-/152311279791?hash=item237675b0af:g:2SsAAOSwKOJYIpT5
or Supercheap or Repco etc
  • 1 month later...
Does anything speak against this setup:
-Hose from right cam cover to catch tank
-Stock Hose from left to right cam cover
-Properly baffled Catch tank vent to atmosphere
And here comes the part I didn't find anything in this thread:
-Hose from AN10/12 fiitting from sump (above oil level on intake side) to existing left cam cover connecting point (which normally goes to intake before turbo).
Should do the trick same as going directly to the catch tank, am I right?
So I can use the existing port on the cam cover, don't need to modify my catch tank and it is a really high point (maybe less blow by than going directly to catch tank)
1. Venting to atmosphere is illegal on public roads and also sub optimal as venting the catch can to the turbo intake can create a small amount of vacuum which helps to vent the sump.
2. It is better for blowby to go to the catch can because the baflles can take out some of the oil.
3. The optimal setup has two hoses going from the sump to the catch can - one to the top and one to the bottom. The latter can act as a drain to allow oil from the catch can to go back to the sump.
4. You don't mention oil restrictors - did you fit any?
There is of course no absolute right and wrong but the above worked for me and a number of others. Some say that a properly built engine will not have oil control problems but RB30s in particular are prone to them.
Engine is getting rebuild right now. Will add a Tomei Oil restrictor.
No track days at all. Only Street driving. Only a few kilometers per year. Don't see any need for a drain back to the sump, will empty it if there will ever be a drop of oil in it.
Didn't had a catch tank at all before and had almost no oil consumption, but will make the engine bulletproof this time. I don't wanna do it again.
Quote
Main question is, will this work as good as going directly from sump to catch tank? Should not make much of a difference?
Edited by GT-R David
Oil control is usually only a problem when at WOT for a decent length of time such as long straight on the track or extended dyno pull so for a street car you may not experience any problems. Restrictors are a good idea if you have the engine out already.
I used to have a pretty blowy motor, then I read this thread and hory shet the difference was extreme. What I had previously (even with the stock 1.2mm restrictors in the 34) was in the photo. Would get this kind of stuff after any real kind of RPM's happening.
Blocked one of the feeds, and had the drains enlarged as the head was off at the time. Prolonged revving later (as in.. probably hours of it) and maybe 20ml in the catch can. Enough that it wasn't so much oil as Oil + water vapour, greeny sludge at best.
(I got a fitting for my sump but looking at whats IN the catch can... wouldn't want that going back down there)
In any case, just sharing my experiences with this thread and the help it provided!
  • Like 1
Main question is, will this work as good as going directly from sump to catch tank? Should not make much of a difference?[/Quote]
No one has a answer for that?
I guess this means nothing speaks against this solution :-/
Thanks for the link! Was going to ask . Guess u read my mind. And no my dip stick never blows out.
Just thought I'll add...My catch can is connected via the 2 rocker covers--> hose to catch can and vented out.
Cracked ringland on the 6th for sure. Exactly the same problem I had with mine.
Unfortunately is engine out and rebuild time
Hey guys great artical about oil restrictors in rb engines. I have a series 1 rb25det I just put in the tomei 1.5 oil restrictor in the middle oil port and blocked off the back one all together my concern is will my hydraulic lifters still be getting enough oil with the rear one completely blocked off and the middle one restricted? Any info would be greatly appreciated
Thanks
Thanks
Yes
  • 1 month later...
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
