Some nankangs which I beleive helped things along and ypur write you dont have to be young and dumb you can be old......eer too but its road conditions you have to be most carful off. Thanks for the support guys .popped some ribs cartlige which will take a while too heal then take some time and build a better one next time . Dont think I'll paint it black though shows the scratches in the pic's to much ,wot you recon :(
cheers Peter
  • Replies 51
As topic states I walked away from this last friday night
So if anyone comes across an R32 shell let me know time to rebuild again
Cheers Peter
Faaark, dude I sugest getting a cage. Good your ok though.
glad your not too hurts
reality check for the kiddies out there looks like and impact speed of around 30-40 km/h
any faster and you would have been in hospital for a good deal of time and you lucky whatever you hit had a good diameter which helps in a lower speed impact
fatz
Dude ! Glad your ok. Went through something similar about a month ago sitting at an intersection waiting to turn right was hit head on by a Porsch running a red trying to avoid hitting a van doing a u turn at the lights ! Ambo, intesive care the works ! Concrete medium strip got him airbourne on impact, spun 180 and smashed into the back of my line above the rear right wheel ! So I know what youve gone through and as long as your ok the rest dont mean squat !
DAMN
you were very lucky to walk away from that without being hurt champ.
Glad your ok and good luck with the new build up :domokun:
I have a shell with a few goodies but crook motor in Tassie if your interested >_<
Cheers GMB
damn !!!!!!!!!!!
that is a pretty bad accident.....I think you and I both have used one of our nine lives.
I had an accident slightly worse than that a few years back....XF falcon rammed by corolla from behind at 80km/h + and the car flipped vertically and landed on a fence....it was a corolla sedan csi after the accident it looked like a chop top hatchback....
Were you shaking a bit when you got out of the car ??
I know I was....
Anyways at least your ok !!!!
Edited by shonen
Good to read your not too badly banged up. (it good to have a war story, but not have to tell it from a wheel chair) :bunny:
Bugger. Could well of been the country's quickest std RB20...what tyres were you running again? Your thing was half the reason i didnt bother running mine as i knew you were about to put down the numbers and fly the flag
Hope your recovery goes well....and a R32 shell comes your way soon!
Roy engine still running fine not even a water leak after that so when i get a new shell and slip in the running gear I'll try flying that flag again , and silver thanks man
Cheers Peter
P.S I might paint the next one red there suppose to be faster arnt they
wow...
can I ask where you're located to have frost on the road? I've never seen this in sydney..
also, before you ditch the car, please sell me the vents and other internal bits that you won't use in your next car.
glad you came out of it with a little rib pain only.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
