  • Replies 99
Posted Images
One day .. maybe in like 5 years my next car will (hopefully) be a s14 that I can whack a 180 front on.. big wide bodykit.. roll cage.. etc mmm track car.
But if you want to keep your import but have a 'legit' car why not just get a s14 or s15? A lot of business type people own those (... and don't DRIVE them).
P.S. I should also suggest that if you're a high profile employee who can actually make it a talking point and turn it to your advantage etc then it's actually a good thing to be able to have something that stands out. I see people in 200's and other German ford-laser level cars (318's etc) and it seems to be very very common..
For example I'm in a consultancy role at a major and stiff financial company... Whenever I get the chance to go to things in the cefiro I do, it presents like a piece of shit compared to the other cars there and it's not like these people think it's PHAT because it has dish, a kit and induction noise etc, nor do they care how it handles, drifts or goes... But they remember me and the car and think "ahh that bloke likes to modify cars".. That gets me into their consciousness, then it's up to my skill and competency (and bullshit skills) to sell and build credibility..
Other people use other ways to be noticed, like they fit in, work hard and hope they're noticed that way... *shrug* horses for courses mate but either way good luck :D
What does everyone else plan on buying for their next car? Another skyline or a bigger car because you now have a family or.............?
Cheers
Id suggest a nice Series 2 model Stagea.
Whether that be a RS4 (RB25det) or a RS260 Autech GTR Stagea wagon (RB26dett) thats up to you and the wallet.
They look nice, rare, and go like the clappers.
Edited by Tangles
Ferrari of whatever current model.. :P
hmm.. maybe chaser jzx100
Then again, the 'practicality' of a 4 door is not much better than a coupe when it comes down to it (having owned a few)... You still don't have enough boot space for the big long or larger items. For that you need a hatch or a wagon. The only thing it's a bit more convenient for passengers, and well stuff them :D
If "class" wasn't an issue, I'll just keep my R32.. for price, handling, performance (having turfed the rb20), knowledge of the car, power/weight, there isn't much better. It's a bit daggy on the inside these days, but then again what isn't unless you bend over on the price. And whatever else "new" will be ever-outdated in 3 years after that. Why keep playing the game until you die purchasing new cars every few years and blow it all over again? To me that's lame. During that time you could be travelling overseas, buying a business, going on exciting weekend adventures, furnish your house with the best furniture, etc, etc rather than spending maybe 40% of your weekly income maintaining some new car.
I was thinking no matter what you're going to buy you're going to get shafted with the resale and that never makes you get richer faster, so why not just stick to whatever you've blown all the money on
Why not get another Nissan - the 350Z ?
You have a choice of Coupe or Convertible (My wifes choice - her Turn next)
And it would be a corporate approved conveyance :D
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
