32s i found on the net. my 32 is black with stock rims haha
RB20 GT2535 18psi 300whp - the car's 20 years old this month!!! they don't make them like they used-to
ratty drifter, porn
first dibs on this kit if I can find it!
local track radial tyre record holder (in japan) lightened to just over a ton and RB20 with 25 turbo.
cheers
cheers
Front bar vertex
side skirts vertex
and rear bar looks to be final konnexion
vertex parts are easy to get, ive got the side skirts and rear bar on my car
and final konnexion im pretty sure are also avaliable at some of the body kit places to
more details on this thanks.
Cool, I'll do my best but the pics are big as they get on the website I think. I got the pictures from a blog written by Tochi, from shop called YMS. This HCR was brought in by a customer (Super NOW) ‘NOW’ is phonetically spelled for ‘na-u’ (na-u-i), which is ‘trendy’ in Japanese. Who just got the track record for Nikko circuit 38.902 sec for radial tire TOYO R1R (I heard from a local Toyo guy that this is not released as a semi-slick any more, I got them on my car and it’s so soft like a semi ). This car also does the Tsukuba 2000 track in under a minute J sweet.
I read Japanese so I surf the Japanese side of the web.
The blog read something like… the car came in for a check and a possible retune, had the diff ratio changed, different boost controller installed. Base figure was 280hp at the rears, after the tune was 300hp on same RB25 stock turbo on a/m exhaust manifold. And came in later for another tune with an adjustable cam gear. The power was measured by dyno-pack. he might have this thing calibrated to show power at the flywheel, I donno. When I read some of the power figures on his site, all the power readings seems to be high ish. there isn't much info on the site apart from the motor. looks like lexan for glass atleast.
Im putting up all the pics from the web http://blog.goo-net.com/tochi/daily/200909/12
hope you enjoy!
P.S thanks for the kit info
Yeah i also dont rate chromies AT ALL! Your current rims look good on the car though. Black on black can look good but sometimes the rim style is a bit lost cause they don't stand out. But time attack's are fkn sweet!
OOOH those are DAMN SEXY!!!!!!
thanks mate
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
