dude it's not mine; was just commenting from typevu linking images from facebook.
giving me the shits, cause they don't embed noone can see them, but the people who are linking it have it in cache so they think it works fine. BLAH
FACEBOOK IS NOT FOR HOSTING IMAGES PEOPLE
you know i have a flickr :O
It's working fine for me on other browsers installed that doesn't have it cache... I've always linked it from Facebook and no one ever mentioned anything like you have before.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
