Well after a short month of happy ownership i am sorry to say that due to an unfortunate incident involving a person who decided to run a red light, i am now no longer the proud owner of my Skyline. at about 9am this morning her life was taken from her in a cruel and brutal way.
As i was waiting in the intersections of Burke and Canterbury Rds to turn right, the light changed and i moved off. lo and behold the 'gentleman' in question broke the oncoming RED light and slammed straight into my passenger side, wiping it out from A to C pillar and going so far as to buckle the entire substructure and the roof.
it was good while it lasted.
R.I.P. 1990 Nissan Skyline R32 GTS-t Type-M.
https://www.sau.com.au/forums/topic/122386-the-dream-is-over/
:domokun: my sympathys
whats with all these people who cant drive lately, no exageration ive had four near misses in the last two days none of which were my fault and all with my three year old daughter in the car!one in a car park!
hope it all works out for you with insurance etc...
bloody hell...i hate idiots who run reds thinking they the shit......
anyway, atleast u werent hurt - though i know i would feel the same if my cars life was taken away.....
EDIT - actually, taxis do that all the freaking time!! Nearly happened to me and my bro when we were driving the 82 honda civic - then the f**ker just yelled at us, as if it was our fault...stupid fat motherf**ker!! And i remember his face, he looked somewhat like lindsay fox....
Edited by emsta2003
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
