yeah fair enough... its a fair bit for sure. The number plates i want are $2200. WAGGIN. ut at least i get to keep em as long as i want.
Love the steering and horsepower comments in your sig, man. Drive safe!! lol
far out 2.2k??? holy moly... yeah funny enuff just the standard nsw yellow jobs on it at the moment say [AN.01.AH] as in annoyer (if thats a word?!?) yeh man, i value my life, license and car way too much to drive like a doodle head... :happy:
haha yes.. but there are a couple of very clear things that give it away.... what, i wonder?
Shadows (they are missing) and inner rear bar for a start, just on a quick look. Looks interesting that low though.
Looks tops rob, but it is photoshopped right???
ok... shadows and inner rear bar are there, not what i meant though! come on!
front windows were a bit of a giveaway, but it still looks HAWT
and it is also a good way for me to sell the missus on a bodykit :sweat:
huh? front windows?
Shaved door handles is the biggest give-away! Looks awesome like that, though - makes it look that mcuh cleaner! :O
YAHTZEE!!!!
Shaved door handles, took rims out to 110%, lowered tyre profile, lowered car. Subtle but tough, i reckon.
Here is my baby! 203.9kw @ all four! Dyno done on 12psi (tuned since)
Running GCG Turbo (Std mount)
3" dump,cat,exhaust
Intercooler
Walbro Fuel Pump
Elect. Boost Contorller 7psi 10psi 15psi maybe 210kw+?
Im proud, proud... :)
Here is old dyno sorry it was 203.8kw @ all four! my bad!
That was dyno done on 10-11psi now o.k up to 16psi not sure of power
though..@ this boost? It must be more coz it accelerates alot harder
with an extra 5psi!!!!! :)
    • You just need a different blue slip shop (preferably one you regularly use as a mechanic), and make sure the coil overs are as close as possible to standard height
    • yeah the sugar refining companies were pushing for the same in Oz originally, all fuels were going to have 10% ethanol to make them "cheaper" (noting, that the loss in l/100 might be greater than the decrease in price). I guess they won that fight in Canadia
    • GTSboy, thank you again. i’ve been reading all the other SAU RB25 vacuum line threads and you have the utmost patience for people asking “where do my vacuum lines go”. it’s appreciated. i did also enlist a few other RB guys local to me.  i would like to run 5 to 4. turbo pressure side to wastegate actuator. i would like to run 3 to 1. power steering air valve line to intercooler outlet. (this is how it was previously). i was told 2 is the bleed port for the boost solenoid - which i’m not running - so should be capped.   anyone see any problems with that?
    • So yes. All of them. Something like 98% of all fuel in the USA has 10% ethanol: https://afdc.energy.gov/fuels/ethanol-fuel-basics It's labelled as like, AKI, 87, 91, 93 with an E10 or E5 or E15 label on the pump. At a certain point, it's not just "E10" instead of 91. It is 91, 95, 98, and all of them have 10% Ethanol in them. You can also get E85 and E30 which is why you do see some people rolling around with E30 tunes in them.
    • Thanks for the response. This is an 04 EP3 Type R. JDM spec. Fairly certain they're just basic BC racing coils. I do plan to keep as the ride quality on stock I've been told is pretty meh given Sydney roads. If I were to go down that avenue, does NSW require them to be a certain spec (close to original) etc?
