lol i know haha ... used this product to get them off ... then arm got tired ...
got some cutters i've had for about 2weeks now i was sposed to use on it ... maybe next time i give it a full on wash i may think about it ! :yes:
thanks for reminding me buddy
how do i upload pics like the ones here ?
when i do it you have to click on the thumbnail to open .. might make it easie to view
Just type blockquote><p>First, you have to host the pictures on an external website (I use <!--url{0}-->, as there
Hmm, I wonder if that is Ryan aka BOZ22N?
this is my new stageas heart, it fired up for the first time saturday and runs like a dream, nice and quiet for a change, its untuned and few minor issues with ecu settings but shouldnt be far off being sorted. Ill post of a pic of the outside of car soon as im doin a few body changes and painting my rims etc soon.
that turbo looks like one of my TD03's with that filter. :wub:
painting the rims black? you know how good black on silver is. :laugh:
the turbo is stock mitchy, just high mounted it :( Im gonna paint rims soon, but gotta go do the hpi photoshoot first before i paint em. I finally got it running on stock coils and ignitor yesterday, runs pretty good, gonna book a tune asap now and then organise the engineer. I got to hand in my plates now so its currently unregoed lol.
Oh and another bonus is i fitted the bonnet on and it closes with about 10mm clearance everywhere so stageas and rb30's are meant to be :)
Edited by unique1
at least it will be responsive with the 'stock' turbo. :sick:
that's plenty of clearance, but then it does have a lot bigger bay than the 32..
i heard a rumour you were selling it and buying a legnum though? something about being a better car??? :)
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
