crank the climate control to like 28 or so... no fog. winnah.
I actually turn the temperature down to get rid of the fog.
Which works better to clear a foggy windscreen, aircon heating up or cooling down?
  • Replies 41
Cold air.
Think of a milk bottle when you take it out of the fridge. It forms condensation on the OUTSIDE, because the room temperature is much warmer than the cold milk.
Same thing. You get fog on the inside of the windows because it's much warmer inside the car than the cold air outside. Turn on the air conditioning as cold as you can get it to quickly normalise the outside and inside temperature of the glass to get rid of the fog.
Voila :D
both work.
But Cold air works x10 faster than warm air, especially if you have just started the car so the air will be warm at best if you use the heater.
in summary, use cold air :D
exactly !!!
so why is this even a topic of debate?
I've been using cold air to clear up the windscreen since the 80's. lol.
everyone knows it's the best way.
Yep, just what I was going to say. I spit in my dive mask, rub it all over inside of the lens, then rinse in seawater before putting it on.
Note: This may prove impractical for in car use. :D
spit?
I just set the fan to high speed, heater to high, and air source to fresh (not re-circulate). If you have re-cric set, you're just reusing the moisture laden air inside the car (from breath, having just come out of the gym or whatever), fresh brings in the moisture free (as it's cold) air from outside. This clears car within seconds.
Warm air can contain more moisture than cold air, so when the warm air inside the car hits the cold windscreen, it cools down, and can't contain all the moisture it has, so dumps it on the inside of the screen. Blowing hot (fresh) air over the inside warms up the windscreen, and as it's got a low relative humidity (moisture free cool air heated up, can then contain more moisture, so the RH goes down), it also takes up the moisture that is on the screen already. As a bonus, it's warm air so won't freeze your nuts off.
depends on whether the fog is on the inside or the outside. if it is on the outside then it is frost forming and you need hot air to get rid of it. you can spray your wipers but it comes back, except where the water actually hit the windscreen.
if it is on the inside then cold air for a short amount of time. if you leave it on too long you end up getting mist on the outside and have to go hot.
and fog-x is ok, but leaves a film which annoys me. i hate and haze on the windscreen. i don't know how some people drive with a dirty windscreen.
Edited by mad082
When I put my e-tag on the windshield it comes with an isopropyl alcohol wipe to clean the glass before you apply the holder.
I wiped the area around where I mounted it liberally, and it didn't really leave a film or anything on the glass (that I could see).
A few days later when it was pissing down raining, the area I cleaned was the only place where it didn't fog up.
I need to find some place that sells that stuff in bulk for cheap.
Fog-X didn't work for me (I found it fogs up worse) but I might have overapplied it.
charlier34 = from your name im guessin u have r34 or ur description says rb20det, wat car u got ???
i dont think on r32 u can have the air blowing on the windscreen without havin the ac on. but all i do is have the ac on and up the temperature to medium/warm. jus cauz u got the ac on duznt mean u cant set temp to warm so u dont freeeeeze.
u get isoprophyl alcohol from chemists :thumbsup: hope that helps
i didnt know until like 2 weeks ago that demister was onli on the back, lol
that was news to me then i realised my air con was on cold since i bought my car LOL i pay little attention to detail. cold air works a charm ;) just wear lots
of clothes if ur planning to go far
hey guys thx for the responses... i forgot and it is stupid of me for not stating that somehow my air-con doesn't work(maybe it needs a air-con regas, but let assume that air-con doesn't work at all ^_^) :/ haha i guess that explains how this debate popped up... and im pretty sure theres a few cars out there that has this problem to(i think) :thumbsup:
jvs007; i do have an r34... but i haven't edited my details hehe to lazy
A/C de-humidifys the air, thats the main point. If its cold, i chuck the climate control on about 24deg with A/C ON with the vents going to the windscreen, that works pretty quick. Cold A/C works a touch quicker.
  • 2 years later...
while warming up the car, hose the outside of the windows
set air con to OFF but allow it to flow the hot engine air through the feet vents and windscreen vent.
roll with windows slightly down(doesn't bother me as im a smoker)
rug up!
That's all i ever use the air con for.
I hate that No-Fog/Fog-X/Never Fog stuff, because it leaves an oily film on the windscreen that makes it look dirty and hazey in the sunlight... and if you wipe all of the oily stuff off, then you've just wiped off the product and it does sh1t-all!
I find just keeping the inside of the windscreen PERFECTLY clean and spotless is the best option. Then 10 seconds with a blast of hot air demists it quick as a flash! When your windscreen is dirty though, it takes AGES to demist the glass.
Absolutely agree with everything Merli said
Keep it very clean, and you are less likely to have the problem.
Also the RainEx AntiFog stuff is crap as mentioned, I put it on, then took it all off again, just became smeared everywhere.
It is also about keeping the inside of the car dry where possible. So leave umbrellas etc in the boot and anything else that is wet. I occasionally put a tub of those moisture absorbing things in the car overnight over a few days. It sucks up all the moisture in the air and converts it to water in a tub. You can buy it from the supermarket. It helps, especially when the air is very humid in the car, and moisture is attached to your carpet, seats etc.
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
