just a word of advice
take your steering wheel off
THe same bit you use to take off the airbag module under the console, is the same type used on the side of the wheel to hold on the horn pad. then its a 21mm nut under the horn
then disconnect the two connectors and yank it off.
Well just to be careful, when I removed my steering wheel, I disconnected battery, then hit the brakes, tried turning the headlights on, to drain any residual power left in the system, then gently unplugged the airbag control unit, then unplugged the airbag, and did the reverse to hook it all back up, hooray, no airbag error light after 5secs of the car running.
Well I didn't need to anyway, I have the new brake pedal box installed and the steering wheel back together.
This is a milestone for me as I've been doing everything at night with a hand held torch. I have many cuts and bruises now.
One of the hardest thing I found to do was removing and refitting the smallest part, the saftey pin on the brake pedal to booster rod.
lol, i just turned the car off, and unpluged the airbag.....i dont think ive ever unhooked hte battery for it
and no airbag light....cause there isnt wont
Do you mean there isnt one? Yes there is, middle of the dash in the centre of the speedo.
That wasn't too bad for me. They hardest bit I found was getting that top bolt back into the pedal box. It took me about half an hour just to get that in. apart from that, I found that once you've undone all the bolts you can twist the whole steering column to get the bracket out of the way, and then the pedal box goes in really easily. I wish I'd figued it out while I was taking the old one out.... oh well, we live and learn
I got my clutch in the other night, but forgot to stick a picture up. I managed to install the master cyliner, then realise I'd forgotten to put the clutch line in, which wasn't possible to install with the master cylinder in. So out it came, I put the line in an then back it went. All one now, however the engine is in pieces and I'm short a turbo, so no gearbox yet :D
Well I know it's not directly related to the Manual conversion,but I got my new turbo in last night. First time it seems really hard, but if I had to do it again it would be so much easier now I figured out the hard bits.
I'm going to clean up the gearbox next, then next week some time book her in for a gearbox swap!
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
