  • Replies 459
1 peice of warning. that room looks crazy dusty. I wouldn't run it in there if you can avoid it. also definately put it up on a table, not on the carpet when you are using it.
and :laugh: old news! I got mine a month ago to the day. :huh:
hope you enjoy it :)
Ahh now that looks awesome.. Bit bigger than the PS2!!
Might need to get one anyway.. Got the 360 ( Media Center Extender ) and the Wii ( cant see the PS3 being able to meet the Wii standards for tennis and boxing!! )
This would finish off my Entertainment room rather well!
And double up as a Blue-Ray Player as a bonus. ( Will wait till they drop down to around ~ $600ish ) $1000 is just over the top.
+ How many Blue-Ray Movies are on the market at the moment..
  • 1 month later...
Just got a japanese PS3...Wondering if the power system is truly universal as it says 100V on the PS3. Did you guys who got one from japan use a transformer?
If so, what did you do with the earth wire??
Cheers
Well it is a next gen console and why would sony bundle it with a HDMI cable? It supports HDMI yes but does everybody who is going to buy console have a TV that supports HDMI the answer to that is no. Even though LCD TV's are now being sold more then the old tube format but even buying an LCD doesn't mean it will have HDMI.
Well I am still waiting for sony to announce the release date here (meant to be done by the end of the month) so I can go and collect my pre-order in March (if all goes to plan).
Ok then, well not everyone has a tv that supports AV, so should they drop that and just go with RF?
It doesn't even come with component cables as a bare minimum, in fact it doesn't come with any cables that allow any sort of HD viewing.
Seems a bit strange to me.
Those graphics do nothing for me.
Wheres the heat coming off the cars?
Look at the texturing for the roads, theres no dilution just perfect tarmac, ditto for the rumble strips and grass.
They crowd barely do anything just stand there and occasionally clap.
Edited by kralster
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
