The 30" diameter makes the 315 tires look like they belong on a Model T Ford.
... got...
.... to...
... stop...
...myself...
...from...
aaaaaaaaaarrrrrrrrrrrrrrrrggggghhhhhh!!!!!!!!!!
They're gay. :P
yo jigga yall cant roll like dis im rollin on twenny fo's fo sho yall know how we do.
ok il stop now FARRRRRK 30's i wonder if they come in spinners yo!!! i wonder whats next 40's? 60's?
im looking to get a set of 17's for my car...i think im going to cry now
uuhhhh, it was a lambo he cut the roof off. 30's have been around for a while, i remember seeing em in an old mag a few years back, although they werent fitted to a car then. i dont see why you would buy a H2, then put 150k rims on it when you could buy 2 more H2s and go cruisin wit da homiez, but thats just me...
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
