Fast Ford, Performance Ford **prepares for flaming :)
I am struggling to find decent ones here without cars with 20" chromies or cars from pre war. :D
I shall use this thread almost as a suggestion thread to go and scout out potential decent mags. :)
I'm into performance cars / race cars. I subscribe to Drift Battle and Austalian Muscle Cars. I love the history in old race cars and how they used to make cars go fast and drift battle because all of the cars in it are built for drifting on a track. As it's been said. 20" chromies and 10 TV screens doesn't do much for me. I wanna see them on the track.
Curious to know which magazine would be more effective for advertising
MOTOR is the best....but English.
High performance imports is the place if your thinking of ads.
Why do you have to be so far away from me?
Which area you from?
I am from campbellfield Ray.
Had a convo last week about an oil cooler installation.
Maybe i have more reason now to come and get this fixed too. :D
Look Ill make you a deal...Ill work with you to work on this car of mine. Same price as you would have charged normally.
This way I can stay the whole day and not have to catch a train anywhere.
:) Im afraid the gearbox issue would take few days.
Its pretty much HPI now Ray.
Speed was a great mag that unfortunately died :D
Joel might be able to give some other idea...
But if you wanna advertise, i'll come chat to ya about sponsorship :nyaanyaa:
Least you wont have 15yr old kids ringing you about getting some dose for thier mirage
Yeah, I definately want to do something with SAU.
I always find myself browsing HPI and wheels at borders in chaddy. HPI is better for imports obviously, but wheels is also good for everyday cars and so on. Depends on what you want to target - I found out about RE Customs from SAU.
how about other forums?
IMO the best mags out now are Zoom & HPI....i subscribe to both :D
drift battle can sometimes be good too...
agreed, i was feeling a bit angry that no-one had mentioned zoom. anyone hear that reads HPI, should most definately pick up a copy of zoom, so they can se what they are missing out on, its basically HPI, but more content relative to aus, with some of the best technical articles from anywhere. HPI and zoom i buy every issue (they have been probably the biggest part of my education), and quite a few drift battle, with some street machine/autosalon/speed(have quite a few since b4 it died)
anyone know why speed went under?
I really dont read any mags now save for wheels or motor
The HPI's/Zooms etc i've found to be mainly filled with ads and some very much inaccurate topics and feature cars.
I mean, reallistically you'd think the editors would get the article at least technically checked.
You should know when someone is bullsh|ting for an article... it certainly doesnt look so good when the print something thats pretty much impossible.
Its like me saying ive got 400rwkw from a pair of GT-SS.
Everyone knows its impossible. But hey, i'll give ya a dyno sheet that says so :sorcerer:
Yeah, I noticed that with Fast 4s and HPI, they slowly fill up with more ads and less content, but Wheels has always been quality
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
    • It's amazing how well the works on the leather seats. Looks mint. Looking forward to see how you go with the wheels. They do suit the car! Gutter rash is easy to fix, but I'm curious about getting the colour done.
