won't come up in my version, says invalid model number. Which I think means it was made later than my fast data. Your sure its 2002?
Thanks for your quick response
Was told it was 2002.....could I have needed more numbers for you....ie....another 7 letters maybe..like all other vins?.
Now I am stuck......I will have to check with the importer, check the auction sheet and get back to you
for interpretation....
VIN NO. : 6U9000ECR33102890
Model: R33
Series: GTST Type M
Built: Jan 1996
Colour: Sonic Silver
Body: 2 door coupe
Transmission: 5 speed manual
VIN: bnr32302958
Model: R32
Series: GTR
Built: April 1993
Colour: Gunmetal Grey Metallic
Body: 2 door coupe
Dear SMR33,
Is this FAST program 100% accurate?
My Skyline was imported and complied with a build date of "June 1998". However, I had a feeling this was inaccurate as I remember reading somewhere that R33's finished production in March 1998?
Someone please confirm this for me.
Thanks.
R33's built in 1998 would be the 40th anniversary skylines and as such should have special badging, and interior touches. When production ceased on the R33's I am not sure, however the number I checked for you had a build date of June 1997 (according to FAST). FAST is only as accurate as the information entered into it at the time.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
