Guys help me out with this r34 its got a nur engine bnr34401083
You sure it's got a N1 Engine (Nur)? Unless it's had an engine replacement?
R34 GTR V-Spec II Nur's only came in 6 colours:
Millennium Jade (JW0) / Bayside Blue (TV2) / Pearl White (QX1) / White (QM1) / Sparkling Silver (WV2) / Pearl Black (GV1)
The VIN you posted says = KV2 - Athlete Silver
And I believe the VIN is for a R34 GTR V-Spec II (Stock RB26DETT) as it states it has larger rear rotors.
The Build Date is March, 2001 and V-Spec II Nur's were built from February 2002.
Unless it's a V-Spec N1 or a V-Spec II N1 but from memory they only came in Crystal White (326).
100% sure its a nur engine took out the plugs and it has AB0 pistons which are nur spec, 05u head with a 24u block
ECR33112614
Thanks guys
Ok sure, that was my next question about the Block Number.
Pics of the engine?
Cant see the turbos to see if its got the n1 turbos
Yeah again, check the part number for the turbos, thanks.
Hi could you please check this Vin for me.
BNR32222923
would like to know paint code?
V-spec or not?
if possible to tell if its a pull type or pust gearbox
thank you
KostaGTR
Looks to be Base Model
Colour is Gun Metal Grey
From memory, it was either late '92 or '93 were Pull Types...
Hi there can I please get this vins details
6U9000ECR33106944
thank you very much
Hi, could you check this VIN for me please?
BCNR33005555
V-spec or base model
Model no. has a "Q"
"W" would be a V-spec
Anyone can confirm
No VIN Match, check the number or take a photo of blue plate and lets have a look, thanks.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
